Thread: Deselect Some of Selected Objects
    2018-07
    Default Deselect Some of Selected Objects
    Hi,
    For a project I need to prevent the user to modify objects which belong to a specific Layer.
    below is my VBA code to do this.I used "SelectionChanged" event to trigger the program. I can loop through objects that are selected by user.The problem starts when I want to deselect the objects that are in "Block" layer. Actually, I can't find any way to deselect them.I will be very glad if you can help me.Many thanks in advance
    Private Sub AcadDocument_SelectionChanged()
    Dim pfSS As AcadSelectionSet
    Dim ssobject As AcadEntity
    Dim msg As String
    msg = vbCrLf
    Set pfSS = ThisDrawing.PickfirstSelectionSet
    For Each ssobject In pfSS
    If ssobject.Layer = "Block" Then
    '' Here I dont know how to deselect!!
    msg = msg & vbCrLf & ssobject.ObjectName
    MsgBox "The Block Object Type Is: " & msg
    End If
    Next ssobject
    End Sub
    Turlock, CA
    6,409
    Default Re: Deselect Some of Selected Objects
    Use the AcadSelectionSet.RemoveItems method. You can't simply execute the method in your For..Each loop because then the selection set will be changing on each loop. Therefore, you need to add the qualifying items to an array of AcadEntity objects. After the For..Each loop completes, then you can run the RemoveItems method and pass it the array of entities to be removed.
    C:> ED WORKING....
    LinkedIn
  1. Setting X to selected objects
    By mbrandt5 in forum AutoLISP
    Last Post: 2015-08-13, 02:09 PM
  2. Hold down Shift key to deselect Objects not working
    By smooth shoes in forum AutoCAD General
    Last Post: 2010-08-18, 09:08 PM
  3. "Nothing Selected" message when Objects are Selected
    By mark.81576 in forum AutoCAD General
    Last Post: 2007-04-13, 05:00 PM
  4. Objects not regenerated / selected.
    By nata_hs in forum AutoCAD General
    Last Post: 2004-12-30, 01:02 PM
  5. Permanently hiding selected objects (not objects-by-category)
    By cjneedham in forum Revit Architecture - Wish List
    Last Post: 2004-06-28, 12:18 PM
