Thread: Need help with my code.
    Default Need help with my code.
    Hello to All
    Thanks to those that will help with this one.
    I need help with my code. I am trying to draw an offset Tee with autolisp, but am having trouble with pt8. I have included two programs, one is TO-Offset Tee which works perfectly. The other is TOSD , this one is the one that I need help with. I cannot get the (pt to go plot correctly.
    Javier
    2003-07
    561
    Default Re: Need help with my code.
    Just look at pt3 but polar from pt1
    I would look into a dynamic block then can just pick from a "look up" the correct size combination.
    Thank You
    I looked at pt3 as you pointed out and my code worked, thank you so much for your help.
  1. Allow Other Code Compilers for ARX Code
    Last Post: 2013-02-10, 08:06 AM
  2. code help
    By rphillips.137763 in forum AutoLISP
    Last Post: 2009-02-04, 12:18 AM
  3. Insert vbscript code has not code
    By buzz in forum AMEP General
    Last Post: 2008-02-09, 03:08 AM
  4. Convert VBA code to VB code
    By Robert Platt in forum VBA/COM Interop
    Last Post: 2007-08-15, 10:13 PM
