Results 1 to 10 of 11
Thread: Vehicle Tracking
    2009-11
    Raleigh, NC
    944
    Default Vehicle Tracking
    I have done the googling and seen all the replies essentially saying you have to accept the warning message unless you upgrade to the current vehicle tracking.
    Is the vehicle tracking embedded in Civil 3D now or is that a additional outside application running that another user has installed?
    I feel like this is one of those unnecessary products that will gum-up Civil3D and I would like to track the source so that if it is not an embedded Civil3D product I can isolate the source and plan other measures to keep it out of my dwgs.
    Earth
    9,805
    Default Re: Vehicle Tracking
    It's not embedded into Civil 3D.
    With a C3D install (2017 and later I believe), there is a folder that gets created in "C:\Program Files\Autodesk\Autodesk Vehicle Tracking 20xx" - but AFAIK, it just contains files to allow you to see AVT objects. Essentially an Object Enabler.
    R.K. McSwain | CAD Panacea |
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Vehicle Tracking and other software comes with the current "Architecture Engineering & Construction Collection", but was not included with the older "Infrastructure Design Suite". Like rkmcswain said you wouldn't have anything more than an Object Enabler if all you're paying for is Civil 3D.
    2008-03
    Columbia/Jefferson City, MO
    224
    When we upgraded to 2018 with the AEC collection Vehicle Tracking has it's own tab in the ribbon. I have been using it on a current project to create parking lot layouts and to make sure my parking lot is big enough for a vehicle with a trailer. So far, I have not found it to "gum" up anything and have been happy with the results. Just my two cents.
    2001-03
    Tallahassee, FL USA
    3,667
    Quote Originally Posted by tntdraftsol View Post
    As they're intelligent objects they can be edited at any time which is a major improvement over the AutoTurn software we used to use. It aggregated me that it was never included with Infrastructure Design Suite as either it or AutoTurn are needed to design most turning movements. I haven't had any issues with Vehicle Tracking either.
    2009-11
    5,719
    For efficiency, FWIW; I document for users what the pertinent radii are for various vehicles, so 'design' can be done per criteria without the need for AutoTURN or AVT.
    Also note that AVT 'breaks' backwards comaptibility from 2019 --> 2018... In annoying as helk message form only... Because of poor programming (no actual harm is done to DWG database, AFAIK): https://forums.autodesk.com/t5/civil...y/td-p/8051334
    Cheers
    Computer Specs:
    All AUGI, all the time Liamnacuac's Avatar
    2016-01
    Earth
    508
    I have seen contractors that are still on projects in 2016 (for some reason) that have scripts they use for printing thousands of .pdf's, and these broke because of the pop up messages. Although I see the obvious solution, I also see the obvious problem.
    2001-03
    Tallahassee, FL USA
    3,667
    Quote Originally Posted by Liamnacuac View Post
    Seems to be working great for everyone that's used it, what problem do you see?
    Reality is that turning movements for design vehicles like garbage, school, or fire trucks are typically required for most civil projects. Vehicle Tracking does a better job than AutoTurn. While there is freeware alternatives for doing this I doubt if any of them would be accepted by a permitting agency.
    2016-01
    Earth
    508
    The problem is when someone is relying on a product to work consistently based on tools that have been in existence for twenty years or so, and without warning Autodesk adds a product that, although is beneficial in almost all aspects, causes a irreversible error for a user who may not have the time to look for another solution. What I mean by the obvious solution is, follow Autodesk's protocol for upgrading, and this would not be an issue.
    I have used both, and I kind of feel it's a little apples and oranges, only from a development point of view. Autoturn has been around a long long time, and they have built their product on a platform based up and toward a market, whereas Autodesk has had the advantage of starting fresh and with a better market idea. I remember Vehicle Tracking being a module for Civil 3D a couple of versions back, wasn't it?
    2001-03
    Tallahassee, FL USA
    3,667
    Correct, though it's been around for many years before that. Autodesk bought it in 2013.
    Autodesk Expands Infrastructure Design and Analysis Portfolio with Acquisition of Sam and AutoTrack Software
    https://lidarmag.com/2013/08/20/auto...rack-software/
    While Autoturn was widely used in the US AutoTrack has always been more advanced and used more outside the US. While we'd looked at it many years ago we stayed with Autoturn because it was cheaper. Once it became part of a package from Autodesk it was a no brainer. No more compatibility issues or having to wait to use a new Civil 3D release till the new release of Autoturn came out.
  1. 2016: Vehicle Tracking Verses Autoturn?
    By Liamnacuac in forum AutoCAD Civil 3D - General
    Last Post: 2016-11-30, 06:49 PM
  2. 2014: Vehicle Tracking
    By rmk in forum AutoCAD General
    Last Post: 2015-03-05, 06:34 PM
  3. 2014: Autodesk Vehicle Tracking
    By MCS in forum AutoCAD Civil 3D - General
    Last Post: 2014-05-01, 08:41 PM
