Thread: inventor 2018 File Export Options
    2002-03
    Default inventor 2018 File Export Options
    I need to convert Inventor 21018 drawings into AutoCAD. The normal process is to Save As, Save Copy As, [Select the format (in this case AutoCAD dwg)], then select Options.
    Problem: It does not allow me to select options. Result: The file saves Zipped instead of dwg.
    Have I missed some setup step?
    Turlock, CA
    6,420
    Default Re: inventor 2018 File Export Options
    Its under the Export menu.
    C:> ED WORKING....
    LinkedIn
  1. 2018: Inventor 2018 shuts down
    By Ukemi72 in forum Inventor - General
    Last Post: 2018-05-07, 10:28 AM
  2. 2018: AutoCAD 2018 Options User Preferences Tab Incomplete
    By CADdancer in forum AutoCAD CUI Menus
    Last Post: 2017-06-13, 07:10 PM
  3. 3D Studio File Export / Import Options dialog box
    By jfsulek in forum VBA/COM Interop
    Last Post: 2008-06-16, 01:13 PM
  4. improved dwg dwf export: export design options in hierachical way
    By studiodd in forum Revit Architecture - Wish List
    Last Post: 2007-02-28, 11:15 AM
  5. Be Able to Export Options to a File
    Last Post: 2006-05-12, 03:12 AM
Tags for this Thread
