Thread: Layer switching from Text file
    2011-12
    Default Layer switching from Text file
    Hi,
    I'm looking for a lisp that will allow me to have several text files with layers in each of them and then run commands to switch the layers in my drawing.
    Example:
    FL text file contains Floor plan related layer.
    RCP text file has Reflected ceiling layer.
    I want a lisp routine that I can type FL and it will freeze all and thaw Floor plan related layer. it would also do this through xref.
    Same for if I typed RCP.
    I know if have seen something like this around just can not find it now that I need it.
    Rich
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Default Re: Layer switching from Text file
    Do you have a sample of the text file for each? You could use this routine to read the file to process the layer names.
    Layer States may be a better option, though.
  1. Replies: 12
    Last Post: 2016-04-19, 06:09 PM
  2. Replies: 7
    Last Post: 2014-06-04, 09:00 AM
  3. Exporting layer info to excel or text file
    By WileECoyote in forum AutoLISP
    Last Post: 2011-07-04, 11:59 AM
  4. switching to Vista 64 - Revit activation switching
    By ws in forum Revit Architecture - General
    Last Post: 2008-06-08, 10:02 AM
  5. Replies: 6
    Last Post: 2007-10-03, 05:21 PM
