Thread: Library Items not showing at all
    2018-07
    India
    29
    Post Library Items not showing at all
    A co-worker is using autocad LT 2017. I use 2018 LT. We are working with an architect that is using 2018(full version I'm pretty sure). In model space and paper space. The doors, some walls, receptacles, and plumbing fixtures are not visible at all to my co-worker. Ever. I talked to the architect and he says he is using Library items for these objects. The only way I can get these items to show up on my co-workers computer is to explode these items 3 separate times and then mess with the layers since all those items were on zero in block space.
    Is there a setting somewhere to not show library items? Or can anyone think of anything else to try?
    Thank you
    Cairo - no, not Illinois
    5,069
    Default Re: Library Items not showing at all
    sounds like he's using the Architecture vertical, niot vanilla Acad. So... he'd need an object enabler. but the architect is on an incompatible version ahead. so that's not going to happen.
    Asnwer -- upgrade the 2017 to the newer version. Heck, you might consider moving everyone to 2019 (but I'd try a 30 day trial and see how that interacts with the architect.
    Earth
    9,805
    I agree about those objects being from a vertical, not vanilla ACAD.
    Actually, I agree about the rest too....
    R.K. McSwain | CAD Panacea |
    Turlock, CA
    6,420
    The architect could use the EXPORTTOAUTOCAD command and save as 2013.
    C:> ED WORKING....
    LinkedIn
  1. Revit: Items showing up on all floors that shouldn't be
    By Magzilla in forum Revit - Platform
    Last Post: 2015-02-23, 01:23 AM
  2. 2013: Plan Region showing items beyond Boundary
    By thomas.denney836893 in forum Revit Architecture - General
    Last Post: 2013-06-19, 05:19 PM
  3. 2013: Frozen items showing on Prints
    By charlielgolden in forum AMEP General
    Last Post: 2013-04-24, 05:20 PM
  4. 3d view showing items outside the box
    By LynNV in forum Revit MEP - General
    Last Post: 2010-06-17, 10:27 PM
  5. Showing Items above
    By DaveP in forum Revit Architecture - General
    Last Post: 2008-09-09, 05:18 PM
Tags for this Thread
