Thread: Changing file attributes with lisp
    Roanoke, Va.
    28
    Default Changing file attributes with lisp
    Is there a way I can change the attribute of a file to read-only with lisp?
    6,419
    Default Re: Changing file attributes with lisp
    Its built into vba, but with lisp, you can use DOSlib from www.mcneel.com. Use the dos_attrib command.
    LinkedIn
    126
    ... or write your own,
    (defun SetRO (/ afile fso ofile ro)
      (cond
        ((and (setq aFile (getfiled "" "" "" 4))
              (setq fso (vlax-create-object "Scripting.FilesystemObject"))
              (setq oFile (vlax-invoke fso 'GetFile aFile))
         (vlax-put-property oFile 'Attributes (setq ro (- 1 (logand 1 (vlax-get-property oFile 'Attributes)))))
         (princ (strcat "File set to " (nth ro '("Read-write" "Read-only"))))
         (vlax-release-object oFile)
         (vlax-release-object fso)
    Roanoke, Va.
    28
    Thanks everyone, Stig had what I was looking for.
    126
    Don't forget Robert McNeel has what you are looking for. I just thought it'd be more fun to write one.
    6,419
    If you're referring to McNeel, I provided you a link in post #2.
    LinkedIn
  1. Changing attributes color bylayer...?
    By aport in forum AutoCAD LT - General
    Last Post: 2018-09-11, 02:18 PM
  2. Replies: 3
    Last Post: 2012-05-07, 08:16 PM
  3. Replies: 10
    Last Post: 2008-02-21, 07:44 PM
  4. Changing all attributes with the same tag
    By todd.mackay in forum AutoCAD General
    Last Post: 2005-11-21, 04:26 PM
  5. Changing the order of attributes
    By kdayman in forum VBA/COM Interop
    Last Post: 2005-02-15, 11:46 PM
