Results 1 to 1 of 1
Thread: using cut geometry in a wall loses my material?
    The Silent Type
    2016-05
    Default using cut geometry in a wall loses my material?
    Hi, first time posting here.
    Been using Revit MEP for a long time, new to Architecture.
    Revit 2017
    So anyway, my problem is that i used cut geometry to make an indent into a brick wall, yet the cut area shows up as flat grey, not brickwork. (see attached).
    To make the indent, i made a model-in-place, made the category 'wall'. and used the void extrusion model to make the shape and then used it to cut the geometry.
    The wall is a basic wall type (see wall settings attachment)
    I first thought my indent went to far into the wall and hit the next layer, but that wasn't it. I also tried to hide the model i'd made.
    so yeah, how do i make the indented area show the same material as the wall it is placed on?
    thank you, ill check back here tomorrow.
  1. join geometry and material takeoff
    By Ning Zhou in forum Revit Architecture - General
    Last Post: 2010-08-11, 09:33 PM
  2. Complex wall geometry
    By eirik.kjolsrud in forum ACA General
    Last Post: 2009-08-25, 04:28 PM
  3. Curtain wall in wall - cut geometry tool
    By ws in forum Revit Architecture - Tips & Tricks
    Last Post: 2008-04-28, 01:50 PM
  4. Replies: 0
    Last Post: 2007-12-21, 02:22 PM
  5. Joined geometry loses setail level settings
    By A3D in forum Revit Architecture - General
    Last Post: 2005-05-29, 04:37 PM
