Thread: Adding field to Sheet List Table
    2007-07
    Minnesota
    69
    Default Adding field to Sheet List Table
    I’ve got my SSM, and I’m about to export a Sheet List Table – but I’m trying to add additional Data Type columns. Specifically, the “Filename” property. Is there a way to add such values that are not already in the list, or am I stuck with the default listing? I can add a custom property of “Filename” but that’s not linked to the actual filename (unless there is a way to double link – but I doubt that) - and would be vulnerable to error.
    Default Re: Adding field to Sheet List Table
    I'm not aware of if it can be done but I don't think so. If you just look for an exported list in Excel our SSMPropEditor can help as it will export the file name too.
    Jimmy Bergmark
    JTB World - Software development, customization and consulting
    Owner/Developer
    Homepage: http://jtbworld.com
    Blog: http://blog.jtbworld.com
  1. Sheet List Table
    By Steve Smith in forum AutoCAD Sheet Set Manager
    Last Post: 2014-06-30, 04:30 PM
  2. Link Sheet set to Sheet List Table and Excel
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2013-05-19, 05:52 AM
  3. Replies: 1
    Last Post: 2006-12-12, 07:36 AM
  4. Replies: 3
    Last Post: 2006-04-26, 02:35 PM
  5. Sheet List Table
    By afortier in forum AutoCAD Sheet Set Manager
    Last Post: 2005-06-01, 10:40 AM
Tags for this Thread
