Thread: Arcs in blocks issues
    Member devilfrog's Avatar
    2015-11
    Tampa, FL
    37
    Default Arcs in blocks issues
    Just upgraded office to AutoCAD Architecture 2019 from 2018.
    I've run into an issue where blocks that contain arcs "explode" on the prints. By explode I mean they separate from the block and scale up several times over, creating these random arcs across the page. This occurs regardless of print destination, PDF, DWF, and paper or model space / paper space. An arc drawn on its own (not part of a block) prints correctly. I've attached an example. Been working on this most of the day so any help would be appreciated!
    btw...AutoCAD Architecture 2018 prints these same files correctly.
    Any ideas?
    2003-03
    Philadelphia, PA
    2,392
    Default Re: Arcs in blocks issues
    Did you install the 2019.1.1 Update? If so, be sure to also install the September 7, 2018 Hotfix for selection and dynamic blocks:
    https://knowledge.autodesk.com/suppo...ix.html?v=2019
    2015-11
    Tampa, FL
    37
    Yes, I did the 2019.1.1 update but didn't know about the Hotfix. The hotfix seems to have resolved the issue. Thanks for the assist!
  1. Sharing Dynamic Blocks - Palette & Catalogue Issues
    By Warr_E_Er in forum Dynamic Blocks - Technical
    Last Post: 2014-08-13, 09:15 PM
  2. Any Issues with XREF Title Blocks/ Borders?
    By chillme1 in forum CAD Management - General
    Last Post: 2009-01-13, 12:00 PM
  3. issues! dynamic blocks with attributes.
    By emodderman in forum AutoCAD General
    Last Post: 2008-02-14, 04:51 PM
  4. ARCS
    By victoria in forum AutoCAD General
    Last Post: 2007-10-08, 05:05 PM
  5. Anyone had any issues using mviewblocks in Dynamic blocks?
    By CADMama in forum Dynamic Blocks - Technical
    Last Post: 2006-01-23, 07:39 PM
