Thread: Publish Won't Let Me Select My Page Setup
    2013-06
    63
    Angry Publish Won't Let Me Select My Page Setup
    So, I have a tool that creates sheetlists and publishes them all to PDF. It has worked perfectly for 6 years, and today I found a problematic file, but I am not sure what the issue is.
    I've nailed it down to a specific file, and it SEEMS as though the icon being shown (please see attached image) is a hint to the issue, but my Googling isn't helping.
    The circled icon is the troublesome file. When I open it, it looks to be exactly the same as the other files in the folder. When I manually tried to publish this folder, I noticed this icon is different, the "3D DWF" box is not available, and if I try to use the dropdown to select the page setup, it appears to let me do it, but you cannot select it.
    I feel like this is a very simple fix, but I don't know what the issue is. Any guidance is appreciated.
    5,446
    Default Re: Publish Won't Let Me Select My Page Setup
    What version of acad are you using? Can you post the file?
    2013-06
    63
    So, I always use AutoCAD 2010 for everything, because the newer versions are so much slower and more bloated. Turns out, this issue does not manifest in AutoCAD 2016, and 2018; honestly never even thought to try.
    So, I still have no idea what the actual problem is, but at least my solution can be, should this be an issue, to use a newer version of AutoCAD, and just deal with the performance hit for those specific packages.
    Thanks!
    5,446
    It could be a problem with the file. Since you have 2018, try opening it in 2018 and then save back as 2013.
  1. Publish error Page Setup works Publish won't
    By jmagarolas962356 in forum AutoCAD Plotting
    Last Post: 2011-02-11, 12:29 AM
  2. 2011: Can't publish using page setup overrides
    By Craig_L in forum AutoCAD General
    Last Post: 2011-02-08, 01:55 PM
  3. Publish to Alternative page setup
    By burchd in forum Project Navigator
    Last Post: 2008-06-03, 06:27 PM
  4. Page setup scale in publish USUALLY works
    By phoulx in forum AutoCAD Plotting
    Last Post: 2007-08-10, 05:23 PM
  5. Applying a Page Setup to all drawings in Publish
    By neilcheshire in forum AutoCAD LT - General
    Last Post: 2007-06-22, 07:03 AM
