Thread: Lisp modification
    2018-09
    5
    Default Lisp modification
    Hi all
    I have a routine able to align objects to a reference without displacemente. But i can only select one object and i would like to be able to select some objects with a selection box. I tried to modify ssget but it was not enough (:S single selection)
    Could it be possible? thanks.
    (vl-load-com)
    (defun C:RotTo (/ var ev getobj :angle2UCS ent obj ang-in ang-to)
      (defun :angle2UCS (ang / ucs)
        (setq ucs (- ang (angle '(0 0 0) (getvar "UCSXDIR"))))
        (if (< ucs 0.) (setq ucs (+ ucs (* 2 PI))))
        ucs)
        (defun VAR (typ)				; build variable name with number
        (read (strcat typ num))
      (defun EV (typ)				; evaluate what's in variable name with number
        (eval (read (strcat typ num)))
        						;GETOBJ from ReportAngle.LSP by Kent Cooper, 11/2011, edited for UCS
      (defun GETOBJ (esel num / edata etype subedata subetype path pt1 pt2)
        (while (not (and (setq edata (if esel (entget (car esel)))
    			   etype (if esel (cdr (assoc 0 edata))))
    		     (set (var "pick"); = pick1 or pick2
    			  (osnap (cadr esel) "nea")); for (vlax-curve) later; also prohibits things like text elements of Dimensions
    		     (wcmatch etype "ARC,LINE,*POLYLINE,@LINE,RAY,INSERT,HATCH,DIMENSION,LEADER,*SOLID,3DFACE,WIPEOUT,TRACE,REGION,IMAGE,VIEWPORT,TOLERANCE")
    		     (or (wcmatch etype "ARC,*POLYLINE")
    			 (not (osnap (ev "pick") "cen")))    ; if Polyline/Block/Region/3DSolid/angular Dimension, not on arc/ellipse segment or circle/arc/ellipse element
    		     (cond
    		       ((= etype "INSERT")
    			(and (setq subedata (entget (car (nentselp (ev "pick"))))            ; then, use nested object -- same checks as above, except:
    				   subetype (cdr (assoc 0 subedata)))                        ; no center Osnap check [earlier check covers it] ; no Insert or heavy Polyline object types [never returned by (nentselp)]
    			     (wcmatch subetype "LINE,LWPOLYLINE,VERTEX,@LINE,RAY,HATCH,DIMENSION,LEADER,*SOLID,3DFACE,WIPEOUT,TRACE,REGION,IMAGE,VIEWPORT,TOLERANCE")
    			     (if (= subetype "LEADER") (= (cdr (assoc 72 subedata)) 0) T); STraight, not Splined
    			     (if (= subetype "VERTEX") (= (boole 1 8 (cdr (assoc 70 subedata))) 0) T))); not Splined 2DPolyline
    		       ((= etype "LEADER") (= (cdr (assoc 72 edata)) 0)); STraight, not Splined
    		       ((= etype "POLYLINE") (= (boole 1 4 (cdr (assoc 70 edata))) 0)); not Splined 2DPolyline
    		       (T)))) ; all other object types
          (prompt "\nNothing selected, or not a straight object with linearity --")
          (exit)); while
        (cond ((wcmatch etype "ARC") ;arc
    	   (setq path (car esel))
    	   (set (var "ang")   ; = ang1 or ang2
    		(angle (setq pt1 (vlax-curve-getStartPoint path))
    		       (setq pt2 (vlax-curve-getEndPoint path))))
    	   (grdraw (trans pt1 0 1) (trans pt2 0 1) 7 -1))
    	  ((and (wcmatch etype "*POLYLINE") ;arc segment of polyline
    		(angle (setq pt1 (vlax-curve-getPointAtParam path (fix (vlax-curve-getParamAtPoint path (trans (ev "pick") 1 0)))))
    		       (setq pt2 (vlax-curve-getPointAtParam path (1+ (fix (vlax-curve-getParamAtPoint path (trans (ev "pick") 1 0))))))))
    	  ((wcmatch etype "POLYLINE,XLINE,RAY"); vlax-curve-applicable types
    		(angle '(0 0 0)
    		       (vlax-curve-getFirstDeriv path (vlax-curve-getParamAtPoint path (trans (ev "pick") 1 0))))))
    	  (T
    		(angle (setq pt2 (trans (osnap (ev "pick") (if (= subetype "RAY") "nea" "mid")) 1 0))     ; account for Ray in Block [no midpoint]
    		       (setq pt1 (trans (osnap (ev "pick") (if (= subetype "XLINE") "nea" "end")) 1 0)))) ; account for Xline in Block [no endpoint]
    	   (grdraw (trans pt1 0 1) (trans pt2 0 1) 7 -1)))
        (set (var "ang") (+ (ev "ang") PI))
        (if (> (ev "ang") (* 2 PI))	  (set (var "ang") (- (ev "ang") (* 2 PI))))
        (ev "ang")
      (if (and (setq ent (ssget "_+.:E:S"))
               (setq ent (ssname ent 0))
               (setq obj (vlax-ename->vla-object ent))
               (setq pnt (getpoint "\nReference point: "))
               (or (not (vl-catch-all-error-p (setq ang-in (vl-catch-all-apply 'vla-get-rotation (list obj)))))
                   (setq ang-in 0.))
               (or (setq ang-to (getangle "\nSpecify final angle <by object>: "))
                   (setq ang-to (:angle2UCS (getobj (entsel "\nSelect to aling to: ") "1"))))
        (progn
          (if (/= (cdr (assoc 0 (entget ent))) "MTEXT")
            (setq ang-in (:angle2UCS ang-in)))
        (command "_.ROTATE" ent "" "_none" pnt "_R" (angtos ang-in (getvar 'AUNITS) 8) (angtos ang-to (getvar 'AUNITS) 8))))
      (princ)
    2015-10
    Belgrade, Serbia, Europe
    564
    Default Re: Lisp modification
    Untested :
    (vl-load-com)
    (defun C:RotTo (/ ss i var ev getobj :angle2UCS ent obj ang-in ang-to)
        ucs)
    		     (cond
    		       ((= etype "INSERT")
          (exit)); while
    		(angle '(0 0 0)
    	  (T
        (ev "ang")
      (setq ss (ssget "_:L"))
      (if ss
        (repeat (setq i (sslength ss))
          (if (and (setq ent (ssname ss (setq i (1- i))))
                       (setq ang-in 0.))
            (progn
      (princ)
    M.R.
    2018-09
    5
    Hello
    I tested and it works, but just one thing: if i want to align 2 or more objects, i have to specify reference point for each one. could be set the same reference point?
    p.d: you only change ssget?
    2015-10
    564
    Quote Originally Posted by enghezt View Post
    Hello
    Yes only change - ssget...
    (vl-load-com)
        ucs)
    		     (cond
    		       ((= etype "INSERT")
          (exit)); while
    		(angle '(0 0 0)
    	  (T
        (ev "ang")
      (if (and ss
                       (setq ang-in 0.))
            (progn
      (princ)
    HTH., M.R.
    2018-09
    5
    Thanks!!
    It works perfectly!!
  1. select result lisp modification
    By chad.beussink in forum AutoLISP
    Last Post: 2023-10-24, 09:55 AM
  2. Modification to a lisp (needs to change the lisp code)
    By nanaji130285733687 in forum AutoLISP
    Last Post: 2016-11-21, 04:45 AM
  3. Small Modification Required, In Existing Lisp
    By prasadcivil in forum AutoLISP
    Last Post: 2016-10-11, 05:45 AM
  4. Modification to a LISP routine
    By cwjean76 in forum AutoLISP
    Last Post: 2008-05-19, 06:32 PM
  5. Brick Lisp modification requested
    By BCrouse in forum AutoLISP
    Last Post: 2008-04-17, 08:15 PM
