Thread: Using lsp and sql to populate a autocad table
    2012-08
    6
    Default Using lsp and sql to populate a autocad table
    Need some advice, is the following feasible with lsp and using a autocad table. I'm attaching a .xlsx file to show what the data looks like and what the autocad table should look like.
    I'm using lsp to query the records from the database, I've never used autocad tables before so trying to determine if this is a even a option. Basically I'd be opening a recordset and loop through getting each record. As you can see from the data table each record will have 3 rows (cubical, office, touchdown) but in the acad table it will consist of 4. Each drawing will vary with the number of records so the table size will need to very based on the number of rows, but the number of columns will always be the same. The headings are static except for the 1st header which will be data driven.
    Any advice would be greatly appreciated, again I've never worked with tables. I've done some research and it appears this might work.
    Thanks
    2003-07
    560
    Default Re: Using lsp and sql to populate a autocad table
    Here is a table create example, that has 1/2 solved you problem you then need a Autocad <-> excel lisp and there are lots of them out there. You then fill the correct table cell address much like excel.
    ; example of creating a table
    ; By Alan H July 2017
    ; sum of column row 10 column 1 ie 2nd column
    ; (vla-settext obj 10 1 "=sum(B2:B7)")
    ; get number of rows
    ; (vla-get-rows obj)
    ; get number of columns
    ; (vla-get-columns obj)
    ; insert a row add only 1 row newrownum +1 to number of columns
    ; (vla-InsertRows obj newrownum (vla-GetRowHeight obj rownum) 1)
    (defun ex_table (/ colwidth numcolumns numrows objtable rowheight sp doc)
    (vl-load-com)
    (setq sp (vlax-3d-point '(0 0 0))) ; or use getpoint
    (setq doc  (vla-get-activedocument (vlax-get-acad-object) ))
    (setq vgms (vla-get-paperspace doc))
    (setq numrows 5)
    (setq numcolumns 5)
    (setq rowheight 0.5)
    (setq colwidth 30)
    (setq objtable (vla-addtable vgms sp numrows numcolumns rowheight colwidth))
    (vla-settext objtable 0 0 "TABLE title")
    (vla-settext objtable 1 0 "A")
    (vla-settext objtable 1 1 "B")
    (vla-settext objtable 1 2 "C")
    (vla-settext objtable 1 3 "D")
    (vla-settext objtable 1 4 "E")
    (vla-settext objtable 2 0 "1")
    (vla-settext objtable 3 0 "2")
    (vla-settext objtable 4 0 "3")
    (vla-setcolumnwidth objtable 0 15) ; 0 is first column
    (vla-setcolumnwidth objtable 1 30)
    (vla-setcolumnwidth objtable 2 60)
    (command "_zoom" "e")
    (princ)
    (ex_table)
    2012-08
    6
    I guess I should clarify this a bit more, the data is not coming from a spreadsheet it's being queried directly from a oracle database. The spreadsheet was a example of how the table should look. Each department returned will have 3 rows of data for Cubical,Office, Touchdown. the example below is a sample of the records returned
    14 0 30 16744448 102 GTS Professional Services Cubical: 16 11 5
    14 0 30 16744448 102 GTS Professional Services Office: 3 3 0
    14 0 30 16744448 102 GTS Professional Services Touchdown: 0 0 0
    14 0 230 16711808 115 Global Technical Services Cubical: 26 24 2
    14 0 230 16711808 115 Global Technical Services Office: 5 5 0
    14 0 230 16711808 115 Global Technical Services Touchdown: 0 0 0
    14 0 81 10485632 55 Human Resources Cubical: 0 0 0
    14 0 81 10485632 55 Human Resources Office: 1 1 0
    14 0 81 10485632 55 Human Resources Touchdown: 0 0 0
    14 0 151 8437759 57 Information Technology Cubical: 50 34 16
    This is a example of how the cad table should look:
    Attachment 106889
    2003-07
    560
    If you can create a csv file of the data it makes it a bit easier as you can make a list from csv reading each line then use the code posed previously to populate the table, look at Lee-Mac.com for csv to lisr
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    You might try ADOLisp for a part of the solution.
  1. 2018: Can A Civil3D Table Be Converted To Regular AutoCAD Table
    By omorah in forum AutoCAD Civil 3D - General
    Last Post: 2018-06-05, 11:40 PM
  2. Excel Table to AutoCAD Table.
    By Spenner in forum AutoCAD Tables
    Last Post: 2017-08-14, 07:17 AM
  3. Replies: 8
    Last Post: 2014-02-28, 06:44 PM
  4. Windows XP - AutoCAd 2004 Slow to populate lookin box
    By RobertAitken in forum Operating Systems
    Last Post: 2008-01-18, 11:35 AM
  5. Linking AutoCAD Object Data Table to Access table
    By m.storey in forum AutoCAD Map 3D - General
    Last Post: 2006-05-02, 02:54 PM
