Thread: VBA - List of objects in a drawing
    2018-07
    2
    Default VBA - List of objects in a drawing
    Hello,
    I have a huge file with numerous objects I need to work on.
    I would like to have the list of all objects and as much information I can get (layer, bounding box, object type etc.)
    I would like to generate this list in VBA.
    Any ideas?
    Thank you
    Turlock, CA
    6,421
    Default Re: VBA - List of objects in a drawing
    Autodesk has Managed Debug on GitHub that you could use. It allows you to explore the database. It doesn't give you a list of everything though.
    C:> ED WORKING....
    LinkedIn
    2017-01
    8
    Sub Change_All_existing_To_Layer()
    Dim ssAll As AcadSelectionSet
    Dim mEntity As AcadEntity, oBlkRef As AcadEntity
    Dim blkAtt As String
    Dim ssets As AcadSelectionSets
    'clear selection set
    Set ssets = ThisDrawing.SelectionSets
    On Error Resume Next
    Set ssAll = ssets.Item("AU2013_SS")
    If Err.Number <> 0 Then
    Set ssAll = ssets.Add("AU2013_SS")
    Else
    ssAll.Clear
    End If
    'selects all entries in drawing
    Set ssAll = ThisDrawing.SelectionSets.Add("AllEntities")
    ssAll.Select acSelectionSetAll
    For Each mEntity In ssAll 'loops thru entry list
    If TypeOf mEntity Is AcadBlockReference Then 'picks blocks
    Set oBlkRef = mEntity
    If oBlkRef.HasAttributes Then 'picks blocks with attributes
    blkAtt = Get_Attribute(oBlkRef, "BLKSET.FURNISH")
    If blkAtt = "\W0.7500;E" Then 'picks "existing" devices
    mEntity.layer = "STAGE.NOTES.SD"
    End If
    End If
    End If
    Next
    ssAll.Clear 'cleans the selection set
    ssAll.Delete
    Set ssAll = Nothing
    ThisDrawing.Regen acActiveViewport 'regenerates the drawing
    End Sub
    this can pick all entities in modelspace
    then filters blocks with attributes
    and changes the layers of those with "E" on the "BLKSET.FURNISH" attribute
    the speciffic part you might be interested in is:
  1. 2015: "Appears in Drawing List" parameter added to a drawing index schedule
    By ron.randell in forum Revit Architecture - General
    Last Post: 2015-06-25, 09:01 PM
  2. Improve Drawing List to customize drawing order, discipline, etc
    Last Post: 2012-09-25, 05:02 PM
  3. Change Objects Layer by List
    By freedomonek in forum AutoLISP
    Last Post: 2009-02-05, 01:17 PM
  4. Is there an easy way to get a list of all objects on a form?
    By cgerhardt in forum VBA/COM Interop
    Last Post: 2006-10-10, 12:07 PM
  5. Replies: 2
    Last Post: 2006-05-02, 04:41 PM
Tags for this Thread
