Hi,
This is my thread from Autodesk please help me
EXPORTTOAUTOCAD or AECTOACAD these two commands repeat every one or two hour to solve copy object past as block (auto-generated)
Working with Xref file, After reference editing session an object remove from working set Refclose then copy object Ctrl+V its past as block.
After export to autocad new file Clean up WBLOCK, AUDIT, RECOVERALL again XATTACH Working with Xref file one or two hour it will be repeat Ctrl+V its past as block.
My first solution All XATTACH CAD file also Clean up separately WBLOCK, AUDIT, RECOVERALL.
My second Solution i reset CUIX in cuiload (find the attachment)
I found these two solutions but not use, after one or two hour its will repeat again when i copy CTRL+C & CTRL+V (past will be past as block).
Version Using AutoCAD 2015
Thanks & Regards,
JAYHAR.M.J
Detailing Engineer
________________________________________
CICON Rebar Solutions Pvt. Ltd.
DD Trade Tower, Kaloor-Kadavanthara Road,
Kaloor, Ernakulam, Kerala,India - 682017
E-mail : jayharcicon@gmail.com Mob : +91-9961032444
