I stumbled upon Peter Jamtgaard's reactor a long time ago, and have tailored it for specific variables I find CAD changing on me, works great. However, in 2018 my dynmode portion stopped working. I tested and confirmed it still works in 2016 and 2017, but in 2018 this is what I get on the command line.
Enter new value for DYNMODE <3>: 0
; error: AutoCAD variable setting rejected: "DYNMODE" 3
I checked to make sure that Dynmode numbers hadn't changed in 2018, but it looks the same. I even tried changing my reactor to keep it set at 1 instead, but I get the same thing. Dynmode started at the bottom of my reactor as well, and I bumped it up to see if
Full reactor below
(vl-load-com)
(setq VTFRXN (vlr-editor-reactor nil '((:VLR-sysVarChanged . VTF))))
(defun VTF (CALL CALLBACK)
(if (and(= (strcase (car CALLBACK)) (setq str "DYNMODE"))(not (eq (getvar str) 1)))
(progn
(setvar "DYNMODE" 1)
(if (and(= (strcase (car CALLBACK)) (setq str "SAVETIME"))(not (eq (getvar str) 30)))
(progn
(setvar "SAVETIME" 30)
(if (and(= (strcase (car CALLBACK)) (setq str "PICKFIRST"))(not (eq (getvar str) 1)))
(progn
(setvar "PICKFIRST" 1)
(if (and(= (strcase (car CALLBACK)) (setq str "FILEDIA"))(not (eq (getvar str) 1)))
(progn
(setvar "FILEDIA" 1)
(setvar "savetime" 30)
(setvar "pickfirst" 1)
(setvar "filedia" 1)
(setvar "dynmode" 1)
(alert "Variable Reactor Loaded Successfully")
Any idea to this?
Thanks
