Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: How to get error message text?
  1. #11
    6,419
    Default Re: How to get error message text?
    Quote Originally Posted by guillermo.suar View Post
    My question is if the error message about is stored somewhere and can be retrieved.
    Although possible, generally, a plugin like this wouldn't store such messages. You could try looking into the Windows error messaging system and see if anything is written there, but I doubt it. Look in the Start menu, Administrative Tools, Computer Management. The Event Viewer has a filter for Applications and Services Logs.
    LinkedIn
  2. #12
    2006-06
    7
    The message is generated by AutoCAD, not Windows so I was hoping It would be as easy as reading a variable but if nobody knows I guess I'm out of luck.
  3. #13
    2006-06
    7
    Did not find a solution but I have a workaround using accaddoc.lsp to rename the script when AutoCAD opens. So far so good.
  1. "Open Text Failed" error message???
    By KELLI in forum CAD Management - General
    Last Post: 2017-08-22, 12:18 PM
  2. Replies: 8
    Last Post: 2009-10-27, 12:03 PM
  3. Replies: 12
    Last Post: 2006-12-07, 03:22 PM
  4. Replies: 2
    Last Post: 2005-12-06, 06:17 PM
  5. Fatal Error: Unhandled Exception" Error Message
    By jkrulicki in forum MDT - General
    Last Post: 2004-07-28, 03:56 PM
