Thread: Attributes upper and lower case lisp modification
    Default Attributes upper and lower case lisp modification
    Dear Helpers,
    I got a lisp code that will update all attributes of single selected block to uppercase. But the lisp code I need is, it should update only single attribute to upper or lowercase for selected block. The code I have is below. It should work for multiple blocks.
    (defun c:AUC ( / ent enx )
    (if (and (setq ent (car (entsel)))
    (= "INSERT" (cdr (assoc 0 (setq enx (entget ent)))))
    (= 1 (cdr (assoc 66 enx)))
    (setq ent (entnext ent)
    enx (entget ent)
    (while (= "ATTRIB" (cdr (assoc 0 enx)))
    (entmod (subst (cons 1 (strcase (cdr (assoc 1 enx)))) (assoc 1 enx) enx))
    enx (entget ent)
    (princ "\nNo object selected or selected object is not a block.")
    (princ)
    T.Brahmanandam
    2003-07
    561
    Default Re: Attributes upper and lower case lisp modification
    Please check Cadtutor for reponses.
    2006-04
    466
    https://apps.autodesk.com/ACD/en/Det...en&os=Win32_64
    Ultimate Attribute Edit
    (hope this is not self promotion, fits the question)
    Thak you so much. But my organization don't allow to install addons
  1. 2013: Sheet set manager text a mix of upper case & lower case
    By nextvkin in forum AutoCAD Sheet Set Manager
    Last Post: 2018-03-27, 09:26 PM
  2. Replies: 3
    Last Post: 2007-01-09, 12:42 PM
  3. Upper/Lower case text
    By djn in forum Revit Architecture - General
    Last Post: 2007-01-05, 10:40 PM
  4. Changing from UPPER case to lower case
    By IamSnave in forum AutoCAD General
    Last Post: 2005-02-09, 10:30 PM
  5. Layer names from lower to upper case
    By dqueen in forum AutoCAD Customization
    Last Post: 2004-06-23, 03:05 PM
