Dear Helpers,
I got a code from kent cooper from Autodesk lisp forum, that's working fine. I need a small change in below code that it should ask for block rotation and block Scale. Please change the code as per my requirements.
(vl-load-com)
(defun C:ABR ; = Array Block in Rectangle(s)
(/ *error* ABRia doc svnames svvals P1 rectss n P3)
(defun *error* (errmsg)
(if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
(princ (strcat "\nError: " errmsg))
); if
(if ucschanged (command-s "_.ucs" "_previous"))
; [change to (command ... if Acad version predates (command-s) function]
(mapcar 'setvar svnames svvals); reset System Variables
(vla-endundomark doc)
(princ)
); defun - *error*
(defun ABRia (/ delta LL NX NY colsp rowsp); = ABR Insert & Array
(setq
delta (mapcar 'abs (mapcar '- P3 P1)); differences in XYZ list
LL (mapcar 'min P1 P3)
; Lower Left regardless of pick order or Pline start or direction
colsp (/ (car delta) cols)
rowsp (/ (cadr delta) rows)
); setq
(command
"_.insert" blk "_none" (mapcar '+ LL (list (/ colsp 2) (/ rowsp 2))) "" "" ""
"_.array" "_last" "" "_r" rows cols rowsp colsp
); command
); defun -- ABRia
(vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object))))
(setq ; System Variable saving/resetting without separate variables for each:
svnames '(cmdecho ucsfollow osmode blipmode)
svvals (mapcar 'getvar svnames)
blk (cdr (assoc 2 (entget (car (entsel "\n Select Block")))))
rows (getint "\nNumber of columns (|||): ")
cols (getint "\nNumber of rows (---): ")
); setq
(mapcar 'setvar svnames '(0 0)); turn off command echoing, UCS follow
(initget "Select"); allows S as input to (getpoint) function, instead of point pick
(setq P1 (getpoint "\nFirst Corner of ortho-rectangular area for Blocks, or [Select]: "))
; [if in non-World UCS, returns in current UCS coordinates, not in WCS]
(if (= P1 "Select"); chose that option
(progn ; then
(prompt "\nTo Array Blocks in Rectangular Polyline(s),")
(if (setq rectss (ssget '((0 . "LWPOLYLINE") (90 . 4) (-4 . "&") (70 . 1))))
; multipleselection -- only 4-vertex closed [does not check for rectangularity]
(progn ; then
(mapcar 'setvar svnames '(0 0 0 0)); also turn off Osnap, blips
(repeat (setq n (sslength rectss)); step through selection
(setq rect (ssname rectss (setq n (1- n))))
(command "_.ucs" "_object" rect)
(setq
ucschanged T ; marker for resetting in *error*
P1 (trans (vlax-curve-getPointAtParam rect 0) 0 1); starting vertex
P3 (trans (vlax-curve-getPointAtParam rect 2) 0 1); third vertex [opposite corner]
); setq
(ABRia); run the subroutine to MINSERT
(command "_.ucs" "_previous")
(setq ucschanged nil); [turn off marker]
); repeat
); progn
(prompt "\nNo closed 4-vertex Polyline(s) selected."); else
); if
); progn
(progn ; else [picked a point]
(setq P3 (getcorner P1 "\nOpposite Corner: "))
); progn
); if
(princ)
); defun -- C:ABR
