Results 1 to 6 of 6
Thread: Zoom size in FINDTEXT
    2017-06
    5
    Question Zoom size in FINDTEXT
    Is it possible to modify the zoom size that shows the selected result when using the _FIND tool? I work with fairly homogeneous plans and thousand results.
    So far I have to be closing and entering the command.
    Thanks
    Turlock, CA
    6,420
    Default Re: Zoom size in FINDTEXT
    Its not possible to change the command. However, it should zoom to each instance when you click on Find Next. Is it not doing that?
    C:> ED WORKING....
    LinkedIn
    2017-06
    5
    Yes, it is. But I'd like to obtain a smaller zoom area for locating this area.
    Turlock, CA
    6,420
    I'm afraid there's no way to change that. You could submit a wish to the wishlist to change it.
    C:> ED WORKING....
    LinkedIn
    2017-06
    5
    Ok, I'll try to submit my wishes.
    Thanks for your collaboration.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    The modal dialog box is the issue. Until it's closed there's no way to pan or zoom. If they could simply replace it with a Contextual Ribbon tab like they have with other commands like BHATCH it would solve the problem.
  1. 2014: Control how far Zoom command will zoom out?
    By mbrandt5 in forum AutoCAD General
    Last Post: 2015-05-21, 05:42 PM
  2. Performance issues - Slow Zoom when using the Zoom command
    By gsmith.29521 in forum AutoCAD General
    Last Post: 2005-11-01, 08:53 PM
  3. wheel zoom doesn't zoom
    By dougm.79335 in forum AutoCAD LT - General
    Last Post: 2005-02-17, 07:54 PM
  4. ucsfollow zoom rotates view without zoom extents
    By dbroad in forum AutoCAD Wish List
    Last Post: 2004-10-05, 06:21 PM
