Thread: Create layer from block name and move blocks to the new named layer
    2018-10
    5
    Default Create layer from block name and move blocks to the new named layer
    Can someone help me with a lisp that creates a layer based on block names and then moves the blocks onto the layers that match the block name? I used to have a lisp called BLKNTOBLKL and lost it. All the blocks are currently on Layer 0 and they need to go on layers with their own name.
    2009-11
    5,719
    Default Re: Create layer from block name and move blocks to the new named layer
    Welcome to AUGI.
    (vl-load-com)
    (defun c:BLKNTOBLKL (/ *error* acDoc oBlocks oLayers ss name)
      (defun *error* (msg)
        (if ss (vla-delete ss))
        (if acDoc (vla-endundomark acDoc))
        (cond ((not msg))                                                   ; Normal exit
              ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
              ((princ (strcat "\n** Error: " msg " ** ")))                  ; Fatal error, display it
        (princ)
      (if (ssget "_:L" '((0 . "INSERT")))
        (progn
          (vla-startundomark
            (setq acDoc (vla-get-activedocument (vlax-get-acad-object)))
          (setq oBlocks (vla-get-blocks acDoc))
          (setq oLayers (vla-get-layers acDoc))
          (vlax-for x (setq ss (vla-get-activeselectionset acDoc))
            (setq name (vla-get-effectivename x))
            (if (= :vlax-false (vla-get-isxref (vla-item oBlocks name)))
               (progn
                 (vla-add oLayers name)
                 (vla-put-layer x name)
      (*error* nil)
    Computer Specs:
    2018-10
    5
    I don't know if my previous message had made it through or not, but having my question answered so quickly was amazing. Thank you very much, I really appreciate it.
  1. 2015: Layer State Pull-Down Control Not Displaying Named Layer State
    By rbdome in forum AutoCAD General
    Last Post: 2017-06-10, 11:00 PM
  2. Replies: 8
    Last Post: 2015-05-18, 12:18 AM
  3. Move all Objects within a Block to Layer 0
    By kwong in forum AutoCAD General
    Last Post: 2014-03-26, 09:02 PM
  4. All Autocad Products: Easily move all blocks to zero layer
    Last Post: 2013-12-11, 03:57 AM
  5. Replies: 7
    Last Post: 2006-10-23, 04:18 AM
