Thread: Blocks not inserted at the same point
    2018-10
    Default Blocks not inserted at the same point
    in the blow autolisp program, each time the block is inserted at a different point.
    would be so thankful if you can help.
    (vl-load-com)
    (defun ax (/ pt1)
    (command "insert" "block2" "1705,1425" "1" "1" "0")
    2010-06
    962
    Default Re: Blocks not inserted at the same point
    Hi,
    Just set the system variable OSMODE to zero at the top of the insert commands then reset it back at the end of the routine.
  1. Targeting of where the blocks are inserted.
    By luislhss in forum AutoLISP
    Last Post: 2013-07-16, 05:20 PM
  2. Question about inserted blocks
    By Curt340924 in forum AutoCAD General
    Last Post: 2012-02-03, 01:24 PM
  3. Replies: 12
    Last Post: 2010-09-03, 06:21 PM
  4. When Blocks are Inserted they come in too small
    By JAG in forum AutoCAD General
    Last Post: 2006-04-18, 12:10 PM
  5. Blocks will not redefine when inserted
    By bholden.97697 in forum AutoCAD General
    Last Post: 2005-10-28, 04:56 PM
