Results 1 to 10 of 11
Thread: Need Help : Lisp to draw slope line
    2013-03
    2
    Default Need Help : Lisp to draw slope line
    Hi all,
    Is their any Lisp routine to draw slope line from multiple line in X-Y plane.
    routine:
    1. input slope in %
    2. select line/lines from X-Y plane
    then draw slope lines (rise in Z axis, run any X & Y axis) as shown in attached screenshot.
    Thank you,
    2002-08
    231
    Default Re: Need Help : Lisp to draw slope line
    This?
    (defun errlsp (ch)
    	(cond
    		((eq ch "Function cancelled") nil)
    		((eq ch "quit / exit abort") nil)
    		((eq ch "console break") nil)
    		(T (princ ch))
    	(setvar "cmdecho" v1)
    	(setvar "orthomode" v2)
    	(setvar "osmode" v3)
    	(setvar "blipmode" v4)
    	(setvar "snapang" v5)
    	(setq *error* olderr)
    	(princ)
    (defun C:SLOPE ( / v1 v2 v3 v4 v5 d_pc flag p_o p_f dlt_x d olderr)
    	(setq v1 (getvar "cmdecho")
    	      v2 (getvar "orthomode")
    	      v3 (getvar "osmode")
    	      v4 (getvar "blipmode")
    	      v5 (getvar "snapang")
    	(setvar "cmdecho" 0)
    	(setvar "orthomode" 0)
    	(setvar "blipmode" 0)
    	(setq olderr *error* *error* errlsp)
    	(initget 1)
    	(setq d_pc (getreal "\nGive value of slope in en % ?: "))
    	(initget 8)
    	(setq p_o (getpoint "\nStart point: "))
    	(if (eq p_o ()) (setq p_o (getvar "lastpoint")))
    	(initget "In With")
    	(if (eq (getkword "\nSlope[In/With] XY plane <In>: ") "With")
    		(setq flag T)
    		(progn
    			(setvar "snapang" (atan (/ d_pc 100.0)))
    			(setvar "orthomode" 1)
    			(setq flag nil)
    	(initget 41)
    	(setq p_f (getpoint p_o "\nEnd Point: "))
    	(setvar "osmode" (+ 16384 (rem (getvar "osmode") 16384)))
    	(if flag
    		(progn
    			(setq dlt_x (sqrt (+ (* (- (car p_o) (car p_f)) (- (car p_o) (car p_f))) (* (- (cadr p_o) (cadr p_f)) (- (cadr p_o) (cadr p_f))))))
    			(setq d (* dlt_x (/ (sin (atan (/ d_pc 100.0))) (cos (atan (/ d_pc 100.0))))))
    			(setq p_f (list (car p_f) (cadr p_f) (+ (caddr p_o) d)))
    			(command "_.line" p_o p_f "")
    		(progn
    			(setq dlt_x (- (car p_f) (car p_o)))
    			(setq d (/ dlt_x (cos (atan (/ d_pc 100.0)))))
    			(command "_.line" p_o (polar p_o (atan (/ d_pc 100.0)) d) "")
    	(prin1)
    topomav
    Guest
    Hi, Bruno Valsecchi. I know that the post is old, but what the "With" do in this code. I can not understand it. Can you explain me ?
    Thanks
    2002-08
    231
    Slope[In/With] XY plane:
    "In" : The angle is calculated in the plane XY. (2D)
    "With" : The angle is calculate with the plane XY; -> therefore in the plane XZ (if points are in 3D)
    topomav
    Guest
    I try the code and I deactivate the 3d . But i see that this code works works correct with (+/- to the slope) only for left to right. If I want to go down from right to left I have to write 5% not -5% and this confiuse a little. Is it possible to work for the bothe sides with -% dor down and +% for up?
    Thanks
    (defun errlsp (ch)
    	(cond
    		(T (princ ch))
    	(princ)
    (defun C:SLP ( / v1 v2 v3 v4 v5 d_pc flag p_o p_f dlt_x d olderr)
    	(initget 1)
    	(initget 8)
    	;(initget "In With")
    	;(if (eq (getkword "\nSlope[In/With] XY plane <In>: ") "With")
    		(setq flag T)
    		(progn
    			(setq flag nil)
    	(initget 41)
    	(if flag
    		(progn
    		(progn
    	(prin1)
    topomav
    Guest
    Perhaps we can add an option like this to set the direction. Because is easy every time to say for example (-2% for down ) and (2% for up) for the bouth sides
    (initget "A->B  B<-A")
    Thanks
    topomav
    Guest
    Hi Bruno.Valsecchi. I try to change the code but something is going wrong. Can you help?
    (defun errlsp (ch)
    	(cond
    		(T (princ ch))
    	(princ)
    	(initget 1)
    	(initget 8)
    	(if (eq (getkword "\nSlope[A->B/B<-A] XY plane <A->B>: ") "B<-A")
    		(setq flag T)
    		(progn
    			(setq flag nil)
    	(initget 41)
    		(progn
    			(setvar "snapang" (atan (/ (- d_pc) 100.0)))
    			(setq flag nil)
    	(prin1)
    Thanks
    topomav
    Guest
    Any options? Only for 2d
    2002-08
    231
    Quote Originally Posted by Razor View Post
    Thanks
    A simpler version with (grread) to meet your wish: in 2D and the sign of the slope with respect to the starting point.
    (defun C:SLP ( / var_snap pt_start slope key pt_key pt_end)
      (setq var_snap (getvar "SNAPANG"))
      (initget 8)
      (setq pt_start (getpoint "\nStart point: "))
      (if (eq pt_start ()) (setq pt_start (getvar "LASTPOINT")))
      (initget 1)
      (setq slope (getreal "\nGive value of slope in en % ?: "))
      (princ "\nEnd Point: ")
      (while (and (setq key (grread T 4 0)) (/= (car key) 3))
        (cond
          ((eq (car key) 5)
            (setq pt_key (cadr key))
            (redraw)
            (if (< (car pt_key) (car pt_start))
              (setvar "SNAPANG" (- pi (atan (* slope 0.01))))
              (setvar "SNAPANG" (atan (* slope 0.01)))
            (grdraw pt_start (setq pt_end (polar pt_start (getvar "SNAPANG") (distance pt_start pt_key))) 7)
      (redraw)
      (setvar "SNAPANG" var_snap)
      (setvar "LASTPOINT" pt_end)
      (entmake
        (list
          (cons 0 "LINE")
          (cons 100 "AcDbEntity")
          (cons 67 (if (eq (getvar "CVPORT") 2) 0 1))
          (cons 410 (if (eq (getvar "CVPORT") 2) "Model" (getvar "CTAB")))
          (cons 8 (getvar "CLAYER"))
          (cons 100 "AcDbLine")
          (cons 10 (trans pt_start 1 0))
          (cons 11 (trans pt_end 1 0))
          (cons 210 (trans '(0 0 1) 1 0 T))
      (prin1)
    topomav
    Guest
    Hi thanks for the reply,I add osmode 521 to give the option to snap on Endpoints, Node and Nearest at the End Point , but the snap is enabled but don't snap any ware in the drawing (for the end point). Why?
      (setvar "OSMODE" 521) ; enpoint, node,nearest
    and at the end to return
      (setvar "OSMODE" 13) ;End ,center,node
      (initget 8)
      (initget 1)
        (cond
          ((eq (car key) 5)
            (redraw)
      (redraw)
      (entmake
        (list
          (cons 0 "LINE")
      (prin1)
    Thanks
  1. Replies: 13
    Last Post: 2014-07-01, 02:23 PM
  2. Replies: 2
    Last Post: 2012-07-13, 09:04 PM
  3. Draw line lisp
    By rphillips.137763 in forum AutoLISP
    Last Post: 2012-06-21, 02:05 PM
  4. Replies: 3
    Last Post: 2007-05-23, 11:44 AM
  5. How to draw double slope roof and structure (moved here)
    By fantastic in forum Revit Architecture - General
    Last Post: 2003-06-18, 11:28 PM
Tags for this Thread
