Thread: Best way to model a horizontal wall (eg. a framed Shelf)
    2018-08
    Default Best way to model a horizontal wall (eg. a framed Shelf)
    Hi all,
    First time posting on the forums but have been using AUGI as a resource for years.
    Question: what is the best way to model a horizontal piece of interior wall? I'm designing a small shelf in a restroom and I'd like to be able to show a section cut through the room that shows horizontal metal framing, gyp bd, and tile along the horizontal plane (see yellow highlight in the attached image).
    Thoughts on the best way to model this?
    Thanks!
    2002-09
    Madison, WI
    5,557
    Default Re: Best way to model a horizontal wall (eg. a framed Shelf)
    You've got a lot of options. I tend to like inplace sweeps as they are the easiest to modify. You could use a floor or a ceiling object and the convert to parts to adjust the gyp layer where you want it.
    Dave Peterson
    BIM Coordinator
    Acad - 2016 - Revit 2019 w/ A360 - Navisworks - 3ds 2019 - Ensacpe - Lumion - Win 7 64 - i7-6700K 4.0GHz 32GB DDR4 Ram - Nvidia Quadro K2200
  1. 2015: Wall horizontal reveal prevents wall from wrapping
    By ernestas722334 in forum Revit Architecture - General
    Last Post: 2016-08-10, 10:23 AM
  2. Able to use Pick Entire Wall while dimension Linked Model wall in Host Model
    Last Post: 2013-08-10, 10:04 AM
  3. 2013: Model Horizontal Shaft - Best Method - Revit Architecture
    By Limbatus in forum Revit Architecture - General
    Last Post: 2013-02-14, 12:29 PM
  4. Revit 2013 Wood framed wall questions.
    By pwoolson280930 in forum Revit Architecture - General
    Last Post: 2012-09-24, 06:34 PM
  5. Closet Shelf and Pole on Angled Wall
    By tonyisenhoff in forum Revit Architecture - General
    Last Post: 2006-10-25, 02:28 PM
