Thread: Remembrance and Validation on Scale Factors
    2018-11
    Default Remembrance and Validation on Scale Factors
    Been a while since I've used Autocad and I can't remember some things and/or not sure if I'm remembering right or not. Thanks in advance for helping.
    To the Point: Drawing up a Vicinity Map/Survey for a friend that wants a simple addition to a mobile house. Per county requirements need to show the entire property metes and bounds which is almost a entire quarter section of land. Not a actual survey so accuracy is not necessary, just close enough for general information. What I have to print on is a 11x17. Scaled ArcGIS map to actual (close) size in MS and drew my line work in feet/inches/engineering over map. So, now to get the entire roughly 1/2 x 1/2 mile drawing onto a 11x17, I've scaled the viewport to 1:4000.
    If I assume the "1" to be 1' in a engineering scale that would equate to 0.083 per inch which would make the 4000 equate to 332' per inch in PS.
    Am I remembering correctly?
    Thanks again for your help.
    Marvin~
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    2,990
    Default Re: Remembrance and Validation on Scale Factors
    Since 1'=12" I'd recommend using either:
    1"=300' → 1:3600
    1"=400' → 1:4800
    They don't make a 332 engineer scale.
    You can modify scales in ArcMap to use scale units same as AutoCAD does.
    For large drawing areas I use scales in multiples of miles.
    Tom Beauford P.S.M. - Civil 2019 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    2018-10
    7
    Your answer was helpful as i was having same relatable problem
  1. Drawing scale factors 1:1 or 1:12
    By JRBOURNE in forum CAD Management - General
    Last Post: 2009-09-10, 07:24 PM
  2. Xref insertion points and scale factors????
    By justinpickens in forum AutoCAD General
    Last Post: 2009-01-05, 08:24 AM
  3. Different X and Y Scale Factors
    By Masroor Javid in forum ACA Wish List
    Last Post: 2007-10-17, 01:55 AM
  4. Factors affecting Linetype Scale
    By randyspear in forum AutoCAD General
    Last Post: 2006-06-05, 10:01 PM
  5. Scale factors and formulas
    By whdjr in forum Dynamic Blocks - Technical
    Last Post: 2006-06-02, 02:56 PM
Tags for this Thread
