I have around 80 drawings, in separated folders. I've changed layout name to correct name. It is possible to change DWG filename according to LayoutName?
Have you tried to 'Rename & Renumber' using Sheet Set Manager (SSM)?
Computer Specs:
WoW, thank You! I've never heard about SSM. It looks great.
But the problem is that Rename and Renumer option is not possible (cannot check this option, it is gray)
Ok find a solution.
The reason of grayed, disabled rename renumber, sheet and file name option was the files was synce on gdrive. Even if I've copied synced folder to another place it wasn't possible to rename. But If I've copied only files to antoher not synced folder everything works great
