Results 1 to 7 of 7
Thread: Need help with LISP to set Elevation of selection to Zero by point on object.
    2018-10
    3
    Question Need help with LISP to set Elevation of selection to Zero by point on object.
    I'm looking for a lisp that would allow me to select several entities, select a point, then move all objects selected, from point selected, to an elevation of zero by the WCS.
    Something along the lines of:
    Move
    Select Objects
    Select Base Point
    (automation kicks in)
    Select Second Point
    .z of 0,0,0
    (at) @ ""
    (defun c:mtz ()
       (command "move"
          pause
          ".z"
          "0,0,0"
    The pause is not working as I had hoped and I'm new enough to lisp that I'm not sure where to start with the deeper functions in autocad such as dxf data.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    3,047
    Default Re: Need help with LISP to set Elevation of selection to Zero by point on object.
    FLATTEN (Express Tool)
    or
    CHANGE (Command)
    or
    just set the Elevation to 0 in the Properties Palette.
    Tom Beauford P.S.M. - Civil 2019 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    2018-10
    3
    Thanks Tom, but unfortunately those options will not work for what I'm trying to accomplish.
    I need to move a selection set, by selecting a point on an object (which could be an end point, mid point, nearest point, ect.) and having that point moved to Zero Elevation, while the objects within that selection set maintain the same distances from each other and the selected point (including z distances).
    2012-03
    Houston, TX
    4
    Have a look at the attached Modz lisp. It does exactly what you want, but will allow you to enter the elevation in the dialog box (default is zero).
    This is my own creation, so constructive criticism is welcome.
    I could stop if I wanted to CadDog's Avatar
    2005-06
    So Ca
    435
    Does the job WELL...!!!!
    Thanks for making this job a lot easier...
    Jesse
    aka CadDog © 1994
    All is Well until It Fails
    Remember, that what you teach me here you are also teaching others...
    2012-03
    Houston, TX
    4
    I'm glad you like it!
    2018-10
    3
    This is almost exactly what I am looking for.
    Can you add a second Pick option, that moves the entity first selected to the defined elevation, but all other objects in the selection set maintain relative distance from the first entity?
    It does a great job of what you intended, thank you for sharing!
  1. 2009: Create a Selection set from Civil 3D point group or point description.
    By sdrewinc432892 in forum AutoCAD Civil 3D - General
    Last Post: 2016-08-05, 07:01 PM
  2. Replies: 3
    Last Post: 2014-09-16, 06:29 PM
  3. LISP command to make decimal point act as point marker?
    By JRBOURNE in forum AutoCAD Civil 3D - General
    Last Post: 2012-06-30, 11:37 AM
  4. Object selection using lisp
    By ReachAndre in forum AutoLISP
    Last Post: 2006-10-25, 08:53 PM
  5. changing elevation for civil point object
    By chrisw.94380 in forum Land Desktop - General
    Last Post: 2006-02-07, 02:27 PM
Tags for this Thread
