Thread: Issue renaming layers with special characters
    2015-12
    4
    Default Issue renaming layers with special characters
    Hi, Why sometimes this operation returns wrong:
    (defun c:cvt()
    (setq oldname "ESP - Esquadrias CIR")(setq newname "ANT - Esquadria Círculo")(runtorenamelayer)
    (defun runtorenamelayer()
    	(if
    		(and(tblsearch "layer" oldname)(not(tblsearch "layer" newname)))
    			(COMMAND "._-RENAME" "LA" OLDNAME NEWNAME);;(command "._-layer" "R" oldname newname "")
    	(if
    		(and(tblsearch "layer" oldname)(tblsearch "layer" newname))
    		(progn
    			(command "Laymrg") (foreach e (list oldname) (if (tblsearch "LAYER" e)(command "_Name" e)))(command "" "_N" newname "_Y")
    			;;(command "_.-PURGE" "_La" oldname "_N")
    (princ)
    Being specific, if I load the code with the appload or even in the ACAD.LSP the problem occurs.
    And the result is a strange name:
    If I just copy and paste the code into the command bar it works fine and te name is ok:
    Ok, I am thinking about avoiding special characters in the new Layer names, but in some cases the old layers have them already, and in this situation the operation doesn't rename that old layers, the application just skip them because the names doesn't match.
    TIA
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    3,047
    Default Re: Issue renaming layers with special characters
    Quote Originally Posted by bernardigustavo View Post
    Ok, I am thinking about avoiding special characters in the new Layer names.
    TIA
    That would be in your best interest. Lots of others have had similar issues not just with code, but sorting and filtering as well.
    https://forums.autodesk.com/t5/autoc...386543#M171990
    Tom Beauford P.S.M. - Civil 2019 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    2015-12
    4
    Thanks for answering. I think that isn't the same problem.
    But I think I found a way, reading from a txt file it worked fine. I'll do some experiments to see if the problem remains or not.
  1. Special Characters w Mtext..
    By randyspear in forum AutoCAD Sheet Set Manager
    Last Post: 2010-03-24, 10:02 PM
  2. Special Text Characters?
    By pmcelwee in forum Revit Architecture - General
    Last Post: 2009-03-20, 10:09 PM
  3. Back To Special Characters. . .
    By TerribleTim in forum AutoCAD Sheet Set Manager
    Last Post: 2009-01-29, 07:16 PM
  4. Special Characters - Perpendicular
    By smeyer in forum AutoCAD General
    Last Post: 2008-02-22, 04:50 PM
  5. Special characters
    By cadkiller in forum Revit Architecture - General
    Last Post: 2005-01-03, 05:54 PM
Tags for this Thread
