Hello, does anyone have or can easily create lisp code to create a selection set of all objects excluding civil 3D objects?
I would like to have a function to wblock 2D objects to drawing file.
Trevor
Trevor
You would probably need to make two selection sets. The first set would contain all of the objects in the drawing. The second set would then be created based off of a filter of the ObjectName property. You would probably cycle through the first set for each object to check that property. Most, if not all, of the the Civil 3D objects have a ObjectName prefix string of "AECC".
[Edit] - Selecting non-AECC objects is not necessarily the same as selecting 2D (non-3D) objects, FWIW.Code:(defun c:Wblock2D (/ ss) (if (setq ss (ssget "_:L" '((0 . "~AECC*")))) (progn (sssetfirst nil ss) (initcommandversion) (command "._wblock") ) ) (princ) )
BlackBox thank you!
that is really better and definitely what I need for this, thanks for the code!
Good morning BlackBox, I was testing out the code you had provided me and realized that it collects paperspace objects also.
could I ask you to tweak it to not pickup paperspace objects?
Regards
Trevor
Correct; the code above allows the user to graphically select of any non-AECC object.
Given that even AECC objects created in paperspace are automagically moved to modelspace, they cannot be graphically selected from paperspace per-se.
This will preclude selection outside of model tab:
Code:(defun c:Wblock2D (/ ctab ss) (if (and (= "Model" (setq ctab (getvar 'ctab))) (setq ss (ssget "_:L" '((0 . "~AECC*")))) ) (progn (sssetfirst nil ss) (initcommandversion) (command "._wblock") ) (if (not ss) (prompt (strcat "\n** Command not allowed in " ctab " Tab ** \n")) ) ) (princ) )
Cheers
thanks again BlackBox! this is not the first time you have helped me out.
much appreciated!
Kudos
Trevor
