Thread: PDF in 3D Visual Styles
    2016-12
    9
    Default PDF in 3D Visual Styles
    Hello all,
    I have a point cloud that I need to show over a floor plan. The only format we have the floor plan in is PDF and it's a Raster. Unfortunately, PDF's are not shown in 3D visual styles and Point Clouds are not visible in 2D visual styles. I have tried converting it to a TIFF, PNG, and JPEG, but the quality is still very poor.
    I do have to scale up up the floor plan once in AutoCAD to get it to actual size and I thought that might be causing the issue. I tried scaling down the point cloud down to the size of the floor plan file, but the floor plan is still very blurry.
    Is there something I am missing or some trick to get this to work?
    I'm using AutoCAD Civil 3D, but I don't think it matters here.
    2016-12
    9
    Default Re: PDF in 3D Visual Styles
    I figured out what to do and wanted to share. I should have caught this way earlier than I did, but lesson learned. The PDF floor plan was originally in model space, but after I moved it to paper space, everything worked out as I wanted.
  1. 2011: Problem visual styles
    By Pavlin in forum AutoCAD General
    Last Post: 2014-10-07, 04:59 PM
  2. Visual Styles issue
    By JoshuaV in forum Revit - Rendering
    Last Post: 2011-04-29, 01:51 PM
  3. PDF plotting with visual styles
    By JONatMOT in forum AutoCAD General
    Last Post: 2010-09-28, 07:48 AM
  4. Revised Visual Styles
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2008-10-12, 04:10 PM
  5. visual styles
    By jaberwok in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-06-26, 12:37 PM
