Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Copy Blocks from one DWG to an other DWG
    2009-11
    Raleigh, NC
    581
    Default Copy Blocks from one DWG to an other DWG
    What is the process to transfer blocks from one drawing in to another drawing?
    Is this as frusturating for anyone else or is there some kind of setback bug in DesignCenter now?
    Turlock, CA
    5,480
    Default Re: Copy Blocks from one DWG to an other DWG
    Drag the blocks to the open dwg.
    C:> ED WORKING....
    2009-11
    Raleigh, NC
    581
    Thats not working
    Turlock, CA
    5,480
    Is the open/active dwg different than the one you're dragging the blocks from?
    C:> ED WORKING....
    2015-05
    West Des Moines
    231
    You need to be on the drawing you want to transfer the blocks to. Once in design center (ADC shortcut command) navigate to the drawing you want to take from, select the block category and wait for it to load all the blocks that drawing has.
    As Ed pointed out you can drag and drop if you want, but you can also right click and insert, insert and redefine, or just redefine. If the drawing contains the same block name as the drawing you are taking from it won't use the the other drawing's block, it'll pull from the library currently in the drawing rather than using the other drawing's block definition, which is what the insert and/or redefine function can fix for you.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    2,992
    Quote Originally Posted by tim_newsome View Post
    Thats not working
    Only thing that should prevent that I can think of is if the the block's name is the same as the drawing you're trying to insert it into. That would create a circular reference.
    Tom Beauford P.S.M. - Civil 2019 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    Member joshua.jones's Avatar
    2004-11
    Seattle, WA
    29
    Use Lee Mac's "Steal" app: http://www.lee-mac.com/steal.html
    2001-02
    Another alternate method if your Design Center is getting buggy, is to create a new Tool Palette, and just drag your block into the new Palette, then it will be available in any other drawing, just click and drag, man, click and drag.
    Doesn't answer why the Design Center isn't working, though... I'd guess along the lines of what earlier replies suggested, that the block already exists in your target drawing?
    Hope this helps
    2018-01
    Select block
    Copybase (CTRL-SHIFT-C)
    Pick base point
    Change to new drawing
    Pasteblock (CTRL-SHIFT-V
    Pick insert point
    Simples
    2017-09
    Quote Originally Posted by leshogg762024 View Post
    Select block
    Pick base point
    Pick insert point
    Simples
    Exactly how I do it too.
  1. copy title blocks
    By MikeJarosz in forum Revit Architecture - General
    Last Post: 2015-12-07, 03:10 AM
  2. Copy attributes from blocks to excel
    By Negi in forum AutoLISP
    Last Post: 2013-07-26, 01:47 PM
  3. Copy & Paste Dynamic Blocks
    By tiffany.amorgan in forum Dynamic Blocks - Technical
    Last Post: 2011-07-06, 04:52 PM
  4. copy and paste blocks
    By eeker in forum AutoCAD Action Recorder
    Last Post: 2009-06-18, 03:24 PM
  5. Copy dynamic blocks using an alignment grip
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2006-02-22, 05:33 PM
