Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Copy Blocks from one DWG to an other DWG
  1. #21
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    560
    Default Re: Copy Blocks from one DWG to an other DWG
    Quote Originally Posted by leshogg762024 View Post
    Select block
    Copybase (CTRL-SHIFT-C)
    Pick base point
    Change to new drawing
    Pasteblock (CTRL-SHIFT-V
    Pick insert point
    Simples
    No need to PASTEBLOCK I think, otherwise you will end up in a new block with your desired block inside. Unless you explode afterwards, or actually defining a new block from selected objects.
    Shielbern Bolalin
    Architectural 3D Renderer
    “A clever person solves a problem. A wise person avoids it.”
    1879-1955
  2. #22
    2006-04
    9
    I am using Design center without any problems.
    AutoCAD (vanilla) 2019.
  3. #23
    This is my preferred method and I too have been using ACAD since 1987.
  4. #24
    The old fashioned way of copying all blocks from one drawing into another drawing (just to have the blocks referenced in the drawing for insertion purposes) is simply to use the Insert command for the drawing containing all the desired blocks and when you are asked for an insertion point hit the Esc key. This copies all blocks from one drawing into another.
  5. #25
    Turlock, CA
    5,489
    Quote Originally Posted by rayford.henderson775142 View Post
    However, it won't do a redefine. You just get a message that duplicate definitions were ignored. Its likely that the OP was having problems due to the need to redefine.
    C:> ED WORKING....
  6. #26
    True. Reversing the process might have been used in that case - inserting the drawing with blocks that they wanted redefined into a drawing with those blocks already redefined so the old definition would have been ignored and the new one taking its place. That is what I love about AutoCAD (almost always more than one way to do the same thing) - if one way does not work, try another way.
  7. #27
    2015-05
    West Des Moines
    240
    I'm not trying to pick on you or anyone in specific, but I have to point out that there are efficient ways over inefficient ways. This goes back to what John_C was saying earlier in this thread...kind of surprising there's this much discussion for how simplistic it should be to insert blocks into a drawing because it really should be rather straightforward. Copy/paste should work, and if it doesn't I'd say the other two efficient ways to do this would be to either use the REN command to rename one of the blocks (up to the user at that point) or use ADC to redefine the block. That's like a 5 minute process tops. Maybe there are others, but I don't even agree with the idea to wblock it out because that just seems like a waste to create another drawing.
    Personally I've never agreed with concept that all workflows are equal or "Hey, if it works who cares?" because if you can speed up a workflow without sacrificing something important then it's not a choice, it's just efficiency versus inefficiency. Then again I'm the guy whose polyline command is V because I'm not going to reach across the keyboard for PL.
  8. #28
    2005-01
    4
    I find he advantage of ADC over copy/paste to be that the source drawing doesn't have to be open. Depending on the size of the drawing that can be preferable.
  1. copy title blocks
    By MikeJarosz in forum Revit Architecture - General
    Last Post: 2015-12-07, 03:10 AM
  2. Copy attributes from blocks to excel
    By Negi in forum AutoLISP
    Last Post: 2013-07-26, 01:47 PM
  3. Copy & Paste Dynamic Blocks
    By tiffany.amorgan in forum Dynamic Blocks - Technical
    Last Post: 2011-07-06, 04:52 PM
  4. copy and paste blocks
    By eeker in forum AutoCAD Action Recorder
    Last Post: 2009-06-18, 03:24 PM
  5. Copy dynamic blocks using an alignment grip
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2006-02-22, 05:33 PM
