Thread: Civil 3D objects and drawing can't be saved
    2001-12
    12
    Default Civil 3D objects and drawing can't be saved
    I've started using Civil 3D point label styles to show more attribute data and now when
    I change the point properties to show the new style the drawing will not save.
    I'm getting an error shown in attachment.
    2015-05
    West Des Moines
    240
    Default Re: Civil 3D objects and drawing can't be saved
    My first attempt for this kind of message is to try to save the drawing to the desktop, then save it onto the server which usually fixes the issue. I haven't seen it in a long time but I think I restart CAD after I save it to the desktop then save it to the server.
    There's also a knowledge article about it:
    https://knowledge.autodesk.com/suppo...ed-format.html
    As the article notes you can try an audit command on the drawing to see if it can fix any errors with it.
  1. 2016: Tranforming a Civil 3D objects/drawing
    By mikeosborne in forum AutoCAD Civil 3D - General
    Last Post: 2016-10-11, 02:23 PM
  2. dynamic block saved in its own drawing
    By tomg in forum Dynamic Blocks - Technical
    Last Post: 2014-12-11, 02:08 PM
  3. UCSFollow variable not saved within drawing
    By nathanh in forum AutoCAD General
    Last Post: 2007-09-28, 11:29 AM
  4. Import saved UCS into drawing file?
    By fat.mongrel in forum AutoCAD General
    Last Post: 2007-06-01, 12:53 PM
  5. When drawing were opened and saved
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2006-03-07, 06:32 PM
Tags for this Thread
