Results 1 to 10 of 15
Thread: AutoCAD's Half-Baked Viewport Grip Feature
    Programming Moderator BlackBox's Avatar
    2009-11
    5,378
    2
    Default AutoCAD's Half-Baked Viewport Grip Feature
    Think 2018-2019 AutoCAD's half-baked Viewport Grip feature sucks?
    Me too, so I created a new VPGRIPMODE system variable that allows users to choose how the Centroid & Viewport Grips behave.
    AUGI doesn't support animated .GIF images (for some reason!?), so here's a quick video demonstration: https://www.screencast.com/t/x8nbQlhO3NJt
    I tried to work with the AutoCAD Team on this since 2019 first came out, imploring them to give users the choice... Or I would.
    They've chosen to ignore all requests
    to fix this (not just mine), so to make good on my word, I've just submitted this app to Autodesk Exchange as a FREE app. Not looking for app sales here (it's FREE), just sharing the good news that you'll soon be able to circumvent another poorly done #Autodeskruption.
    Cheers
    VPGRIPMODE
    Initial Value:  2
    Saved In:       Registry
    Type:           Integer
    Change How PaperSpace Viewport Grips Behave.
    0 - Centroid & Viewport Grips Disabled
    1 - Centroid Grip Enabled (Viewport Grip Disabled)
    2 - Centroid & Viewport Grips Enabled (Fixed, No Size Change When Scaled)
    3 - Centroid & Viewport Grips Enabled (Faulty, Size Change When Scaled 'As Designed')
    Computer Specs:
    Dell Precision 3620, Core i7-7700K 4.2GHz, 32GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    3,020
    Default Re: AutoCAD's Half-Baked Viewport Grip Feature
    I've always liked the way defaults were different using grips. Base Point is preselected but still an option, Copy mode must be turned on before mirroring, there's no option afterwards. Most of the time I use them it's because it's the fastest method for what I'm trying to do.
    Until this "triangular scale grip" though grip functions did exactly the same thing as regular functions though they were often more efficient. If I wanted to scale a viewport (for the first time in over a quarter century of using AutoCAD) I'd select a square grip and select Scale from the right-click menu. This new "Feature" makes no sense at all and must have been created by a coder who has never actually done any drawing.
    Tom Beauford P.S.M. - Civil 2019 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    2009-11
    5,378
    Many of us have said the same thing... Autodesk's only response was that this inconsistent behavior was done intentionally, which is an embarrassment. #ShameShameShame #GoT
    I'm not even opposed to the new behavior per-se... Just confused as to why they failed to provide an option to make it consistent (either way), so that changing Viewport Scale via new Viewport Grip, or legacy Properties pane, Quick Properties or Tray icon all behave the same?
    Hrrm... Perhaps I should add a mode to 'fix' for when user wants all Viewport Scale changes to re-size the Viewport?
    Computer Specs:
    Turlock, CA
    5,492
    2018 does it too. Its stoopid. It would be nice to have an option not to use it. I used to have a vba command that was similar. It allowed you to zoom to a view that you wanted, then it chose a standard scale which is nearest to that view. The size of the viewport didn't change. It would be nice to have a combination of yours and mine. I just wish that when you click the triangle grip, it would still show a check on the current scale, but it could highlight the scale that was nearest to the current view. Currently, it just selects "Custom" and you have no idea what scale that is set to. I also had it detect if there was a titleblock with a SCALE attribute and update the attribute.
    C:> ED WORKING....
    2009-11
    5,378
    That's kind of awesome, Ed... I'd love to collaborate on something like that, or help you get your app published if you prefer.
    Yeah, didn't mean to limit to 2019. Initial release in 2018 didn't even obey HIDEXREFSCALES sysvar; how dumb can you be.
    While we will not be able to modify the native Viewport Grip Menu, we can at least report some of that helpful information (i.e., current value and approx/closest Scale?) to Command Line or perhaps even use Transient Graphics (WorldDraw.Geometry.Text()?) near the Grip (just calculate the pixel distance to nearest Editor window edge and place it on the near side, opposite the Grip Menu which always displays on the side with more room or Top when exactly at half way point [so, info under Grip])?
    I also wanted to add a Glyph that indicates when the Viewport is display locked; I remove the Grip (when display locked) in my app, as the OOTB Grip still works, drops down, even lets user pick a Scale (it just doesn't change anything, ya know, because it's display locked).
    As for your automagically setting closest Scale idea, I can see it now... VPSTICKYSCALES sysvar! Haha
    Cheers
    Computer Specs:
    Turlock, CA
    5,492
    Mine is a cmd with a dialog. I got started converting it to .net but never finished it.
    C:> ED WORKING....
    Portland, OR area
    134
    Thanks so much! We all thought the new viewport scaling was strangely designed and I am glad to see someone came up with a solution and is willing to share it with us for FREE! I don't see it on the App Exchange yet but I am watching for it.
    Nancy
    Quote Originally Posted by BlackBox View Post
    2010-09
    In house we have a routine that after you have the correct scale in model space chosen say 1/8" for 1/8" scale plan, it will have you create the box you want in modelspace, flip to layout tab with the sheet on it, allow you to select the anchor point of the viewport. It will then create that viewport and lock it (so you don't accidentally zoom or pan if you click in the space). It was created over 10 years ago, so I don't even know where the script is housed on our system but a very handy tool. The same person who created that, created tabs at least 3 years before Autodesk included them. Sadly they aren't around anymore, but hopefully this will inspire one of you to do the same to create a one click viewport button that does so much more.
    Quote Originally Posted by NEaton View Post
    Nancy
    2009-11
    5,378
    Looks like this (free) ViewportGrip app has been published; see the link in my signature if interested.
    Please try and break it.
    Happy Christmas!
    Computer Specs:
    2017-01
    Love the idea that the viewport no longer changes size when changing the scale, but I ran into an issue using this app when trying to move or copy a viewport to another location on the sheet. Just doesn't seem to work. The centroid stays at the previous location and the new/moved viewport is blank.
  1. 2015: Grip Editing Viewport in Civil 3D 2015
    By J Rampello in forum AutoCAD Civil 3D - General
    Last Post: 2016-10-28, 04:52 PM
  2. Replies: 1
    Last Post: 2014-11-04, 03:32 PM
  3. screening half a viewport
    By gcameron in forum AutoCAD 3D (2007 and above)
    Last Post: 2009-03-04, 09:03 PM
  4. Replies: 2
    Last Post: 2006-06-16, 07:06 AM
