Thread: Calculate Average U-Value for a tapered roof structure
    2018-11
    Default Calculate Average U-Value for a tapered roof structure
    Hey,
    I am wondering if it is possible within Revit, to calculate the average overall U-value of the roof element when there is a layer of tapered insulation present. The roof would also have different layers, including the structure beneath and the top layers.
    2002-09
    Madison, WI
    5,557
    Default Re: Calculate Average U-Value for a tapered roof structure
    I'm thinking dynamo here. Plot a grid of points on the roof insulation, pull the z value from the points and dump to an excel sheet to calculate the average Z value. In theory that would get you an average thickness of insulation by which you could plug in the R value per inch and get a result.
    Just a thought.
    Dave Peterson
    BIM Coordinator
    Acad - 2016 - Revit 2019 w/ A360 - Navisworks - 3ds 2019 - Ensacpe - Lumion - Win 7 64 - i7-6700K 4.0GHz 32GB DDR4 Ram - Nvidia Quadro K2200
  1. 2016: How do I create a parcel table with area, average width and average depth?
    By Brian Benton in forum AutoCAD Civil 3D - Parcels
    Last Post: 2018-09-14, 02:31 PM
  2. 2014: Tapered Roof Overhang
    By scottyermer in forum Revit Architecture - General
    Last Post: 2014-03-07, 02:38 AM
  3. Sloped Roof with Tapered Insulation
    By architeach in forum Revit Architecture - General
    Last Post: 2010-02-02, 10:47 PM
  4. Tapered roof beams
    By t1.shep in forum Revit Architecture - General
    Last Post: 2008-08-21, 09:21 PM
  5. Flat Roof - Tapered Insulation tip
    By Chris.N in forum Revit Architecture - Tips & Tricks
    Last Post: 2008-04-11, 01:09 PM
