Thread: Copied/Monitored Objects not visible in user's local file
    AUGI Director Kimberly Fuhrman's Avatar
    2015-10
    York, PA
    57
    Default Copied/Monitored Objects not visible in user's local file
    I have a client using Revit 2017.2 on a work shared project. I copied/monitored structural grids into the project, in my local file, and synchronized. A coworker opened a new local file, synchronized, and she is not able to see the copied grids or the dimensions associated with them. If I place other dimensions or other objects, she can see them. She logged into a different machine and was able to see them. Visibility settings are all on. Discipline is set to Coordination in the View Template. One other user is having the same issue. Grids are on the Shared Levels and Grids workset, and are open and editable. No Annotation Crop. Same Revit build (17.0.1158.0). She tried detaching from Central and was able to see them. Any other thoughts on why they are not visible in her local file?
    It requires a very unusual mind to undertake the analysis of the obvious.
    --Alfred North Whitehead
    Kimberly Fuhrman, LEED AP BD+C, Assoc. AIA
    2002-09
    Madison, WI
    5,559
    Default Re: Copied/Monitored Objects not visible in user's local file
    I'd try deleting the local file and dumping the cache for it.
    Then rebuild a new local file and see if that help.
    If she makes a new view in the current file do they show up?
    Are you sure she has that workset for the link loaded and opened?
    Dave Peterson
    BIM Coordinator
    Acad - 2016 - Revit 2019 w/ A360 - Navisworks - 3ds 2019 - Ensacpe - Lumion - Win 7 64 - i7-6700K 4.0GHz 32GB DDR4 Ram - Nvidia Quadro K2200
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
  1. Replies: 3
    Last Post: 2018-11-19, 07:21 PM
  2. 2012: Login profile won't allow user to create Local File
    By BrenDillon-IHA in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2011-09-14, 05:26 PM
  3. Local Files: program to delete local file and create a new local file
    By mailshanegross in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2009-06-03, 02:29 AM
  4. Tagging Materials on Copy/Monitored Objects
    By lageftic in forum Revit Architecture - General
    Last Post: 2008-07-21, 02:56 PM
  5. Replies: 3
    Last Post: 2007-01-26, 06:14 PM
