Thread: Wall assembly | layer numbering and thickness | shared parameter?
    2018-12
    Default Wall assembly | layer numbering and thickness | shared parameter?
    I belive a lot of people struggles with getting out the wall / slab / roof assembly as a schudle or a tag. In Poland we are used to prepare material assembly tables / tag for all the wall used in a project, one like this:
    What I want to do is to make a material schedule that would be sorted by Family/Type then by layer numbering - showing one material for each layer with its thickness.
    I've tried to get out a much as I can but the problem is that I don't know where to find layer numbering parameter (which Revit somewhere has in each type of wall family):
    Maybe I could pul this out of each wall type via a shared parameter? Any ideas?
    2018-10
    Default Re: Wall assembly | layer numbering and thickness | shared parameter?
    Maybe you could do it if you transform the wall in a part (from Modify>create>part) Then you can give the layers individual paramters and maybe even tag them. I have never tried this do, but it's worth investigating. Remember that only shared parameters are taggable.
  1. Wall assembly | layer numbering and thickness | shared parameter?
    By Conrad_LP in forum Revit Architecture - Tips & Tricks
    Last Post: 2018-12-14, 09:34 AM
  2. 2013: Door Family - Reporting Parameter - Wall Thickness; Revit Architecture 2013
    By bmaxwell143848 in forum Revit Architecture - Families
    Last Post: 2015-01-21, 09:21 AM
  3. Reporting the thickness of a wall layer in a family
    By adnamapaul in forum Revit Architecture - General
    Last Post: 2012-10-22, 03:57 PM
  4. Replies: 9
    Last Post: 2012-04-19, 07:04 PM
  5. Wall Height tied to CLG HT Shared Parameter?
    By Willard in forum Revit Architecture - General
    Last Post: 2007-05-07, 01:59 PM
