Thread: WIPEOUTFRAME w/ PUBLISH COMMAND
    2016-12
    3
    Default WIPEOUTFRAME w/ PUBLISH COMMAND
    My WIPEOUTFRAME setting is '2'.
    When I PLOT a single sheet, the wipeout frames do not print.
    When I use the PUBLISH command to print several sheets, the wipeout frames print. How can I fix this so my wipeout frames don't show when I PUBLISH?
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,658
    Default Re: WIPEOUTFRAME w/ PUBLISH COMMAND
    Results vary, try setting it to '0'.
    If that doesn't work try setting FRAME to '0'. It will override WIPEOUTFRAME, IMAGEFRAME, PDFFRAME, etc so no frames will display or plot.
    2016-12
    3
    unfortunately, I'm still seeing wipeoutframes when using the PUBLISH command even with WIPEOUTFRAME '0' and FRAME '0'
    2001-03
    Tallahassee, FL USA
    3,658
    Are you Publishing to PDF?
    https://knowledge.autodesk.com/suppo...348.1539799944
    Otherwize there is a workaround at: https://forums.autodesk.com/t5/autoc...507306#M125348
    If you find a better solution please share it here, the issue varies from one PC to the next. For the ones in our office switching back and forth between settings of '0' and '2' has always worked.
  1. 2014: publish command
    By fmplatt530 in forum AutoCAD Plotting
    Last Post: 2015-11-05, 09:56 PM
  2. 2007: Publish Command says unknown command in autocad 2007
    By drajappa594109 in forum AutoCAD General
    Last Post: 2012-07-13, 03:34 PM
  3. Replies: 2
    Last Post: 2006-07-17, 11:42 AM
  4. publish command
    By bbapties in forum AutoCAD Wish List
    Last Post: 2004-11-08, 10:25 PM
Tags for this Thread
