Thread: shape file
    2004-06
    Slidell, Louisiana
    730
    Default shape file
    i have inserted a shape file that has some data associated with it. not in the traditional sense with object data. how can i find the data shown under the category of "feature properties" in the attached image.
    i know how to use the mapanntext command to create the annotated text for the object, but i can't find this category anywhere. this is not the actual drawing with the correct date, just looking for guidance on
    how to find this information. the actual shape file has points with descriptions that i need to display, but comes in just like this.
    Robert
    TN/KY Area
    1,640
    2
    Default Re: shape file
    You say you "INSERTED" the shape file? Did you use the insert command, Mapimport, data connect or drag and drop the file? If it was data connect or drag and drop then in the Map task pane you need to right click on the file and select "Show data table". To display the Map Task Pane use the MAPWSPACE command.
    J. Murphy
    AKA
    Murph
    The former AutoCAD MAP3D Power User
    2004-06
    Slidell, Louisiana
    730
    Okay, I was able to do what you suggested. and the data table shows the information I need. Now how do i annotate the data that's in the comment column?
    update: don't know why, but i was working in C3D 2016 and could not get it to work. We also have 2019, so i tried it in there and it worked like a charm.
    Robert
    2004-06
    Slidell, Louisiana
    730
    well, don't i feel stupid. it turns out the reason the text didn't show up is because it was set to the same color as my background.
    once i changed the text color, everything is fine.
    learn something new every day.
    Robert
  1. "Undefined shape" but no missing shape file?
    By cheshirecatfish in forum AutoCAD General
    Last Post: 2012-01-04, 04:42 AM
  2. PTMARKS.shx is a shape file, not a text font file.
    By tplancon in forum AutoCAD General
    Last Post: 2011-12-09, 09:34 PM
  3. Missing Shape Files / Select Shape File
    By Mac Demer in forum AutoCAD General
    Last Post: 2006-11-05, 01:36 PM
  4. storm.shx is a shape file, not a text font file
    By jgwallace in forum AutoCAD General
    Last Post: 2006-05-08, 01:20 PM
  5. shape file / dbf file size
    By gis.68227 in forum AutoCAD Map 3D - Wish List
    Last Post: 2004-08-20, 01:35 PM
