Thread: Parametrics primer
    2003-08
    Tijuana
    222
    Default
    Hello there. I am new with the program, and unfamiliar with working with parameters to define new familes. What would you recommend to get started with the topic?
    Carlos Sifuentes
    Revit Guru gregcashen's Avatar
    2003-05
    Emeryville, CA
    1,351
    Default Re: Parametrics primer
    Check out the tutorials under the help menu.
    2003-05
    5,153
    Hi Carlos,
    Start with the tutorials.
    Then, open up a standard family, similar to the ones you want to start making and look closely at how they were made, particularly the constraints.
    Golden Rule : Set up the reference planes first, before you make the geometry of the model.
    And "flex" the family at each step, to make sure it works the way you intend.
    It'll be like second nature in no time.
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
    2003-08
    Tijuana
    222
    Thanks. I'll be back after I try it.
    Carlos Sifuentes
  1. Parametrics
    By Doodlemusmaximus in forum AutoCAD LT - General
    Last Post: 2010-06-04, 02:55 AM
  2. smart parametrics
    By clintonc in forum AutoCAD General
    Last Post: 2010-06-03, 03:31 PM
  3. Lacking Constraint Parametrics in Conceptual Massing - not applicable?
    By Helsinki_Dave in forum Revit Architecture - General
    Last Post: 2009-09-10, 09:48 AM
  4. Mi primer ATP !!!
    By alexmirb in forum Español - AutoCAD / AutoCAD LT
    Last Post: 2007-06-18, 09:24 PM
  5. Dictionary primer
    By .T. in forum AutoLISP
    Last Post: 2006-01-31, 05:29 PM
