Originally Posted by
MajorWedgee
I'm having a strange issue with some font types displaying the diameter (%%C) symbol after upgrading to Windows 10. These issues weren't present prior to upgrading to windows 10, when my machine had windows 7 installed. I'm wondering if anybody else has had similar issues and if you had a fix.
We just updated some of our computers from Windows 7 x64 to Windows 10 x64. This is the first round of upgrading windows on some of our older machines. We have about 8 more that need to be upgraded, and about 10 other machines that shipped with windows 10.
Now when we use the diameter symbol on those upgraded machines (%%C) it shoots the symbol off somewhere in the drawing, miles away. This doesn't happen with the unicode version, just Autocad's built in %%C. And it's not with all fonts. It seems to be some TrueType fonts, but not all. For instance we use Tahoma for one client, and with it the diameter runs away. But if you use Arial, it is fine. I've tried different fonts, and with some it's fine, and others not.
If you open the same file on a computer with Win7, everything appears normal. If you open the same file on a computer that shipped with Win10, everything appears normal. But we upgraded 4 machines to Win10, and on all of those machines, if you open it the symbol goes haywire.
It seems to be for anything that uses mtext, mtext, mleaders, dimensions, etc. Single line text appears to be fine.
It seems to only be for the diameter symbol, other symbols (degrees, centerline, etc) all seem fine.
It's not specific to any version of autocad. I tried it in 2015, 2016, 2017, 2018, and 2019, and got the same results in all versions.
If I go into the text editor, and Ctrl+A, and change the font to Arial, then the text all comes back together. I can then change it back to Tahoma, and it is fine, but if you look at it the diameter symbol is still shown as Arial, not Tahoma.
Changing the text style to Arial prevents it from happening on anything new added, but doesn't fix the existing ones. You have to go into each piece of text and select that diameter symbol and change the font to Arial.
I've uninstalled and reinstalled AutoCAD with no change.
I've reinstalled the Tahoma font which i got the file from one of our computers which doesn't have the problem. I wondered if some of the font files had been corrupted on the windows 10 upgrade. Nothing changed.
I got curious about what would happen with a diameter dimension. It works fine. If you explode that dimension, Autocad created the diameter symbol using Arial Font, even though the text style we have selected for the dim style uses tahoma font. This is on both my machine which has the problem, and others who don't.
Our client wants us to use Tahoma font as that is their standard.
Has anyone else ever experienced anything similar? Or does anyone have anything else to suggest trying? At this point I'm baffled. The only thing I can think of is to format the workstations, and install windows 10 from scratch, and just hope that that fixes it. Not ideal. I could try to tell all the drafters to use Unicode for the diameter symbol, or use Arial font when typing %%C, but that seems like a band-aid solution and not likely to be followed 100%.
