Thread: Network Enterprise Workspace
    2018-12
    2
    Angry Network Enterprise Workspace
    Hey guys,
    I am attempting to enforce standards and I have an acad.lsp file up and running on our network that loads an init.lsp routine. This new setup is destroying my user's ribbon in C3D without any input from me (making it go blank). To prevent this I've created an enterprise CUI using materials from AU and loaded into our network and I can't get AutoCAD to work with it:
    (if(findfile "L\\...cuix")
    (command "menu" "L\\...cuix")
    (command "._WORKSPACE" "user")
    I have also set the Enterprise Network Path in Options with the user profile.
    When I type in CUI to check settings, I get the following error "Unable to open customization file:"L\\...cuix" This file has been moved, renamed, or deleted. To fil this file type CUILOAD at the Command prompt."
    How are you guys managing at a CUI / Workspace across your network?
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    3,020
    Default Re: Network Enterprise Workspace
    You may have better luck in the AutoCAD CUI Menus forum:
    http://forums.augi.com/forumdisplay....id=&order=desc
    Tom Beauford P.S.M. - Civil 2019 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
  1. UT228-2: Implementing an Enterprise-Class Telecommunications Network Design Tool
    By Autodesk University in forum Utilities and Telecommunications
    Last Post: 2015-08-07, 05:38 PM
  2. Replies: 1
    Last Post: 2011-11-21, 07:44 PM
  3. AutoCAD 2008 - Setting up an Enterprise CUI file on a network?
    By mmilko.83044 in forum AutoCAD CUI Menus
    Last Post: 2007-05-18, 12:15 AM
  4. Replies: 1
    Last Post: 2006-09-20, 09:43 PM
  5. Toolbar Image problem with Network Enterprise CUI
    By james.emoore in forum AutoCAD CUI Menus
    Last Post: 2005-08-01, 11:33 AM
Tags for this Thread
