Results 1 to 1 of 1
Thread: Get Polyline information from a Dynamic Block
    2014-10
    14
    Post Get Polyline information from a Dynamic Block
    Hello AUGI Users –
    I’m looking for some help to grab the polyline information from a dynamic block and place that information into an attributed table in the same drawing.
    The dynamic block has 2 stretch parameters. These parameters allow the user to stretch the polyline to the desired width and height. The program should only use the maximum vertical and horizontal lengths of the polyline (‘X’ and ‘Y’). These values would be used to populate the attributed table. The format of those values should be fractional (precision set to 1/32).
    I have attached a sample drawing with both blocks mentioned above.
    Thank you in advanced for your help with this.
  1. Replies: 8
    Last Post: 2021-08-26, 06:16 PM
  2. Replies: 2
    Last Post: 2013-06-04, 02:59 AM
  3. Replies: 1
    Last Post: 2012-02-16, 06:58 PM
  4. EMERGENCY!!! - Dynamic Block Information Lost
    By savaytse66 in forum Dynamic Blocks - Technical
    Last Post: 2008-06-23, 05:34 PM
  5. controlling table information from a dynamic block
    By james.126519 in forum Dynamic Blocks - Technical
    Last Post: 2007-12-04, 04:46 PM
Tags for this Thread
