Thread: PDF issues
    2004-01
    8
    Default PDF issues
    just wondering if anyone has LT 2002 and has tried to post Adobe PDF to a website. I only get the pdf in "model" space so my titleblock doesn't show.
    I am ordering LT 2006 does that application accept the pdf conversion to tabs?
    Thanks!
    JAR
    13,499
    Default Re: PDF issues
    Hi
    How are you creating your PDF files?
    Have a good one, Mike
    2004-01
    8
    Adobe Acrobat 7.0 Professional...
    But none of the icons are found in LT2002 so I have to open the file directly in Adobe and I only then get the file in model space. Make sense how I'm explaining?
    James A. Ruggiero
    13,499
    Hi
    I do not have "Adobe Acrobat 7.0 Professional", but you should also have an Adobe PDF Windows Printer, try using this output device to Plot directly to PDF from within AutoCAD.
    A search within the forums will turn-up a lot more information on Adobe and PDF.
    2004-01
    8
    That worked perfectly!
    Thank you so much...
    James A. Ruggiero
    Registered Architect
  1. PDF Issues
    By Taylor1 in forum CAD Management - General
    Last Post: 2011-01-31, 09:03 PM
  2. IFC issues
    By the.one in forum Revit Architecture - General
    Last Post: 2009-11-09, 08:17 PM
  3. Autodesk Issues Tech Bulletin: Service Issues Affecting Revit9-Based Software
    By jobcaptain in forum Revit - Known Issues & Work-Arounds (Read only)
    Last Post: 2006-05-02, 04:25 AM
