Results 1 to 6 of 6
Thread: Pick and Speak
    I could stop if I wanted to aaronic_abacus's Avatar
    2006-04
    384
    Default Pick and Speak
    this program speaks what is picked.
    (defun c:SayIt2 ()
     (setq nent (car (nentsel "Pick words to say: ")))
     (setq nentl (entget nent))
     (setq nentv (cdr (assoc 1 nentl)))
     (setq Phrase$ nentv)
    ; (setq Phrase$ (getstring T "Enter string: "))
     (setq Phrase$l (strlen Phrase$))
     (if (> Phrase$l 1000) (setq Phrase$ (substr Phrase$ 1 1000)))
     (vl-load-com)
     (setq sapi (vlax-create-object "Sapi.SpVoice"))
     (vlax-invoke sapi "Speak" Phrase$ 0)
     (vlax-release-object sapi)
     (princ)
    );defun c:SayIt2
    http://www.watsonlisp.com
    Artificial Intelligence for AutoCAD
    Find detail drawings by text and attribute content!
    6000 lines of code and and in development since 1997.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    3,046
    Default Re: Pick and Speak
    Haven't played with this in years. http://forums.augi.com/showthread.ph...-AutoCAD-Speak
    Tom Beauford P.S.M. - Civil 2019 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    2003-07
    319
    sapi is a little slow to play but interesting for (alert "you have picked incorrect object")
    2001-03
    Tallahassee, FL
    3,046
    If you're in a cubicle make sure you're using headphones or having alerts announcing all your mistakes could be embarrassing.
    2006-04
    384
    3 damn lines and boom, cad is talking back! thanks terrycadd!
    now, how about voice recognition?
    2003-07
    319
    I am sorry to disappoint but voice recognition has been around for like 30 years, it is known that talking to yourself is the 1st sign of madness. Yes I have played "line" Autcad responds you pick points etc. "Save" does just that.
    !@#$ is I stuffed up code word for Undo.
    You need a word for Everything it is best if you train it, how many of us have rang the telephone !@$% I just want to talk to someone. Found the solution mumble.
    You can still buy a digitiser, a proficient operator knew where every command was like a typist, would not look, their speed was amazing.
  1. Roof - Pick Walls vs Lines with Pick
    By andrewg in forum Revit Architecture - General
    Last Post: 2007-12-28, 04:28 PM
  2. Speak 4 cad
    By maa in forum Software
    Last Post: 2006-06-30, 12:13 PM
  3. speak to autocad
    By jaberwok in forum Software
    Last Post: 2005-11-09, 08:12 PM
