Thread: SpeedStretch.lsp not behaving
    AUGI Addict madcadder's Avatar
    Too far from the beach
    1,054
    Default SpeedStretch.lsp not behaving
    I've had this for years and I don't remember it acting like this until the last few versions and never had time to fix it. (currently on A2k19)
    Still don't...
    Can someone take a look at it for me, fix it, and possibly improve if there's a better madness to the method?
    SS - sets the stretch distance
    SA, SW, SX, and SD stretches that direction the set distance.
    It appears there is an error in the error handling.
    When I ESC it doesn't set back the snaps. (probably the other variables too)
    Right now, the OSMODE is rem'd out
    ;;; SpeedStretch.lsp version 1.0
    ;;; Copyright 01/29/01 by Tod Winn
    ;;; Fixed bug when no distance originally set. - 08/01/01
    (defun |speedstretcherror| (|msg|)
      (if (or (= |msg| "Function cancelled")
    	  (= |msg| "quit / exit abort")
        (princ (strcat "\nError: " |msg|))
      (setvar "cmdecho" |cmdecho|)
    ;;;  (setvar "osmode" |osmode|)
      (setvar "polarmode" |polarmode|)
      (setq *error* |olderror|)
    (defun c:ss (/ |cmdecho| |currentdist|)
      (setq |cmdecho| (getvar "cmdecho"))
      (setvar "cmdecho" 0)
      (if (= |stretchdist| nil)
        (setq |currentdist| 0.0)
        (setq |currentdist| |stretchdist|)
      (setq	|stretchdist|
    	 (getreal (strcat "\nSet Distance to Stretch: <"
    			  (rtos |currentdist| 2 8)
        (setq |stretchdist| |currentdist|)
      (if (= |stretchdist| 0.0)
        (progn
          (alert
    	(strcat
    	  "\nStretch Distance currently set to 0.0\nPlease set a valid distance"
          (setq |stretchdist|
    (defun c:sa (/		  |ang|	       |currentdist|
    	     |cmdecho|	  |olderror|   |osmode|	    |ent|
    	     |pt1|	  |pt2|	       |polarmode|
      (setq |olderror| *error*)
      (setq *error* |speedstretcherror|)
      (setq |osmode| (getvar "osmode"))
      (setq |polarmode| (getvar "polarmode"))
    ;;;  (setvar "osmode" 0)
      (setvar "polarmode" 0)
      (princ "\nSelect objects to stretch: ")
      (setq |pt1| (getpoint "\nSpecify first corner: "))
      (initget 33)
      (setq |pt2| (getcorner |pt1| "\nSpecify opposite corner: "))
      (setq |ang| 180.0)
        (progn
          (setq |stretchdist|
        (alert
          (strcat
    	"\nStretch Distance currently set to 0.0\nPlease use 'SS' to set a distance"
        (command ".stretch"
    	     "c"
    	     |pt1|
    	     |pt2|
    	     "0,0"
    	     (strcat "@"
    		     (rtos |stretchdist| 2 8)
    		     (rtos |ang| 2 8)
    (defun c:sd (/		  |ang|	       |currentdist|
      (initget 33)
      (setq |ang| 0.0)
        (progn
          (setq |stretchdist|
        (alert
          (strcat
        (command ".stretch"
    	     "c"
    	     |pt1|
    	     |pt2|
    	     "0,0"
    	     (strcat "@"
    		     (rtos |ang| 2 8)
    (defun c:sw (/		  |ang|	       |currentdist|
      (initget 33)
      (setq |ang| 90.0)
        (progn
          (setq |stretchdist|
        (alert
          (strcat
        (command ".stretch"
    	     "c"
    	     |pt1|
    	     |pt2|
    	     "0,0"
    	     (strcat "@"
    		     (rtos |ang| 2 8)
    (defun c:sx (/		  |ang|	       |currentdist|
      (initget 33)
      (setq |ang| 270.0)
        (progn
          (setq |stretchdist|
        (alert
          (strcat
        (command ".stretch"
    	     "c"
    	     |pt1|
    	     |pt2|
    	     "0,0"
    	     (strcat "@"
    		     (rtos |ang| 2 8)
    (prompt
      "\nSpeedStretch.lsp loaded... \nSD=0, SW=90, SA=180, SX=270 degrees \nSS to set distance"
    5,719
    Default Re: SpeedStretch.lsp not behaving
    (defun c:SD () (QuickStretch 0.0))
    (defun c:SW () (QuickStretch 90.0))
    (defun c:SA () (QuickStretch 180.0))
    (defun c:SX () (QuickStretch 270.0))
    (defun QuickStretch (ang / *error* stretch cmdecho)
      (princ
        (strcat
          "\rQuickStretch Angle="
          (rtos ang 2 2)
          " degrees "
      (defun *error* (msg)
        (if cmdecho
          (setvar 'cmdecho cmdecho)
        (cond ((not msg))                                                   ; Normal exit
              ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
              ((princ (strcat "\n** Error: " msg " ** ")))                  ; Fatal error, display it
      (if
        (and
          (or *stretch* (setq *stretch* 10.0))                              ;<-- default stretch increment
          (or
            (setq stretch
                   (getreal
                     (strcat "\nEnter Stretch distance <"
                             (rtos *stretch* 2 2)
            (setq stretch *stretch*)
          (setq *stretch* stretch)
          (setq cmdecho (getvar 'cmdecho))
          (setvar 'cmdecho 0)
         (progn
           (command "._stretch"
                    "_c"
                    "_non"                                                  ;<-- comment out to use osnaps
                    pause
                    pause
                    "0,0"
                    (strcat "@"
                            (rtos stretch 2 8)
                            (rtos ang 2 8)
      (*error* nil)
    1,054
    I looked at that and just shook my head, "freakin _non. What in the world was I NOT thinking."
    But the code is also much cleaner too. That's great.
    I wrote that when I had, maybe, a year's worth of programming experience and haven't had time to think LISP in the last 3 years.
    Thank you very much...
    5,719
    Quote Originally Posted by madcadder View Post
    You're welcome.
  1. Microstation export isn't behaving
    By dwescott in forum AutoCAD General
    Last Post: 2010-08-31, 06:39 PM
  2. References not behaving
    By barrie.sharp in forum Revit Architecture - Families
    Last Post: 2010-06-18, 08:39 AM
  3. Arcs Behaving Badly
    By fgiorlando in forum ACA General
    Last Post: 2007-08-27, 08:04 PM
  4. Walls Behaving Badly
    By rcroke in forum ACA General
    Last Post: 2007-03-30, 02:28 PM
  5. Linetypes between DWG's not behaving themselves
    By r_soula in forum AutoCAD General
    Last Post: 2007-03-22, 07:38 AM
