Results 1 to 6 of 6
Thread: access toolbar button from keyboard
    100 Club tomcarver's Avatar
    2015-11
    Tucker, GA
    106
    Default access toolbar button from keyboard
    Hi Folks,
    I wanted a button for fillet with 0 radius. I finally found what I was looking for and added the star at the beginning so it would repeat until canceled.
    How do I turn this *^C^C_fillet;r;0;; into a lisp program so I can access it from the keyboard.
    Thanks
    2003-07
    561
    Default Re: access toolbar button from keyboard
    A couple of ways the easiest is r0 just make a lisp defun and load it on start up. If you want repeat a bit ugly but add a while to start of, code it will give error but ignore when using Esc to exit.
    (defun c:r0 ()
    (setvar "filletrad" 0)
    (command "fillet")
    The second something I have is R100 r56-75 r0 Just type R then the radius as one word it recognises the R and pulls the radius out of the balance of the entry the use of - for . is necessary as command line uses a period it takes a little to get used to. Also Circle and offset o12-25
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    The Shift key is for many shortcuts in AutoCAD including FILLET with a radius of 0, see shortcut #4: https://knowledge.autodesk.com/suppo...t-autocad.html
    No need to add another command. Learning these six ways to use shift will make you more productive.
    AUGI Addict madcadder's Avatar
    Too far from the beach
    1,054
    For your acaddoc.lsp
    ;;; loads on first use QuickFillet.lsp
    (autoload "QuickFillet.lsp" '("fr" "sf" "f0"))
    The lisp:
    ;;; QuickFillet.lsp version 1.0
    ;;; Created to set a temporary, a permanent, and a temporary zero
    ;;; FILLET radius.
    ;;; Copyright 01/29/01 by Tod Winn
    ;;; Version 1.1 05/08/01 to fix a minor bug, remove UNDO marks,
    ;;; and add a looping of the fillet function.
    ;;; Error function definition
    (defun |filleterror| (|msg|)
      (if (or (= |msg| "Function cancelled")
    	  (= |msg| "quit / exit abort")
        (princ (strcat "\nError: " |msg|))
      (setvar "cmdecho" |cmdecho|)
      (setvar "filletrad" |filletrad|)
      (setq *error* |olderror|)
      (princ)
    ;;; For FILLET with a temporary radius.  Radius is not permanently
    ;;; stored.
    (defun c:fr (/		   |enta|	 |entb|	       |filletrad|
    	     |lunits|	   |luprec|	 |newfilletrad|
    	     |olderror|
      (setq |olderror| *error*)
      (setq *error* |filleterror|)
      (setq |cmdecho| (getvar "cmdecho"))
      (setvar "cmdecho" 0)
      (setq |filletrad| (getvar "filletrad"))
      (setq |lunits| (getvar "lunits"))
      (setq |luprec| (getvar "luprec"))
      (initget 4 "|filletrad|")
      (setq	|newfilletrad|
    	 (getreal (strcat "\nEnter Temporary Fillet Radius <"
    			  (rtos |filletrad| |lunits| |luprec|)
      (if (= |newfilletrad| nil)
        (setq |newfilletrad| |filletrad|)
      (setvar "filletrad" |newfilletrad|)
      (setq |enta| (entsel "\nSelect first object: "))
      (redraw (car |enta|) 3)
      (while (/= |enta| nil)
        (setq |entb| (entsel "\nSelect second object: "))
        (command "fillet" |enta| |entb|)
        (setq |enta| (entsel "\nSelect first object <Return to Exit>: "))
      (princ)
    ;;; For setting a new FILLET radius.
    (defun c:sf (/ |filletrad| |lunits| |luprec| |newfilletrad| |olderror|)
    	 (getreal (strcat "\nEnter New Fillet Radius <"
      (princ (strcat "\Fillet Radius now set to: <"
    		 (rtos |newfilletrad| |lunits| |luprec|)
      (princ)
    ;;; For setting a temporary FILLET radius of zero.
    (defun c:f0 (/ |enta| |entb| |filletrad| |lunits| |luprec| |olderror|)
      (setvar "filletrad" 0.00000000)
      (princ (strcat "\nFillet Radius Temporarily Set To: <"
    		 (rtos (getvar "filletrad") |lunits| |luprec|)
    		 "> \n"
      (princ)
    ;;; eof
    2015-11
    Tucker, GA
    106
    Thanks Tom. I knew about 1 or 2 of these. The others will be handy. How do I get the fillet to repeat so I can fillet multiple lines with out having to hit enter?
    Tom
    - - - Updated - - -
    Big-AL,
    Thanks, can you show me where the while goes and what parentheses it needs?
    Tom
    2001-03
    Tallahassee, FL USA
    3,667
    Quote Originally Posted by tomcarver View Post
    Thanks Tom. I knew about 1 or 2 of these. The others will be handy. How do I get the fillet to repeat so I can fillet multiple lines without having to hit enter?
    Tom
    While there are many ways to do it with a macro or lisp after starting FILET I simply click [Multiple] on the command line or hit keys "M" then "Spacebar".
  1. Quick Access Toolbar
    By KMercier_C3D in forum AutoCAD Civil 3D - General
    Last Post: 2010-10-25, 02:31 PM
  2. Less access keyboard in some cases with SP3??
    By Martin P in forum Revit Architecture - General
    Last Post: 2009-10-27, 05:11 PM
  3. mouse and keyboard button assignment in 2007 GUI
    By cslarson in forum AutoCAD CUI Menus
    Last Post: 2008-01-25, 05:31 AM
  4. Would like Toolbar description to appear under toolbar button
    By danny.139703 in forum AutoCAD General
    Last Post: 2007-05-21, 05:47 PM
  5. Is there an easy way to have a Toolbar button call up another Toolbar?
    By jonathanschade in forum AutoCAD CUI Menus
    Last Post: 2007-04-12, 04:40 PM
