I am doing some architectural interior elevations. Has anyone done hatch pattern for wood grain - book matched? Where can you get good hatch patterns?
CA
CA
Hi CA
Please note I've *moved* this thread from the AutoCAD Tips & Tricks Forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
Thanks, Mike
Forum Moderator
Hi
And a quick forum search returned the following amongst others -
In need of Hatch Pattern
In need of Wood Hatch Pattern
Wooden Hatch Pattern
Have a good one, Mike
Thanks a lot Mike.
I am new at this forum, so did not know where to start.
Frank
I have asked for help before regarding wood hatch, and will do it again. Please provide information as to where I can get hatch patterns for wood.
Thank you
Frank
Have you tried your last thread?Originally Posted by fcapistrano
Hi FrankOriginally Posted by fcapistrano
Please note I have *merged* you new thread into your "old" ( previous ) thread.
Why? - Both are requesting exactly the same information.
Thanks, Mike
Forum Moderator
Links to hatch pattern collections (both free and commercial) are at http://www.cadro.com.au/hatchkit/HatLinks.html
To bookmatch I think you will need to find or draw a suitable woodgrain pattern, mirror it to a second pattern and hatch on either side of the line dividing the two leaves with the two patterns.
To mirror a pattern change each pattern element definition line and save into a second custom pattern file (with a new pattern name):
subtract the first value (an angle) from 180
change the sign of the second value (Xorigin) and
change the sign of the fourth value (Xdelta)
--- For example if you had the following simple pattern for the right leaf
*WOODR,wood grain (right)
; Pattern written by HatchKit Hatch Pattern Editor
; HatchKit (c) Cadro Pty Ltd 1990-2005.
; www.cadro.com.au/hatchkit/
;-Template=wood,wood grain
;-Source =C:\Documents and Settings\...ts\Hatches\Autocad\hatches\woodhatch.pat
;-Date =28/03/2006
;-Time =3:19:27 PM
;-HatchKitVersion=2.5.4.1142
18.4349379518,0.4,0,2.21359574,0.31622782,0.63246,-2.5298198
26.5650366823,0,0.2,1.34164138323,0.447213700128,1.118,-1.11806934917
36.8698802521,0,0.7,1.4000005957,0.20000006703,0.5,-4.50000256118
--- then the left leaf would be
*WOODL,wood grain (left)
;-Template=WOODR,wood grain
;-Source =C:\Documents and Settings\...uments\Hatches\Autocad\hatches\WOODR.PAT
;-Date =28/03/2006
;-Time =3:19:52 PM
143.130119748, 0,0.7,-1.4000005957,0.20000006703,0.5,-4.50000256118
153.434963318, 0,0.2,-1.34164138323,0.447213700128,1.118,-1.11806934917
161.565062048,-0.4,0 ,-2.21359574,0.31622782,0.63246,-2.5298198
You could produce the second pattern by editing the first with a text editor such as Notepad, in MS Excel or by scaling in X by -1 in a suitable program.
hth
Hugh Adamson
