lance.81922
I don't see how the standard command can be changed, but a simple AutoLISP routine would do the job.
To get you started on the lisp, the way to make a default is:
(initget "Yes No")
(if
(not
(setq answer
(getkword
"\nDelete source objects? [Yes/No] <Y>: ")))
(setq answer "yes")
You can either try to write something that prompts like mirror would then feeds the info to mirror -which may be easier- or replace it entirely -which might look more like the native command. Let me know and I'd be happy to help with either option.
