Results 1 to 10 of 14
Thread: Make Autocad start up a little faster.
    2001-05
    Austin, TX USA
    2,201
    Default Make Autocad start up a little faster.
    Here is a trick I found out about from The Mad Cadder blog that speeds up the load time by disabling the digital signature validation.
    1. Right click on the shortcut you use to start AutoCAD, and pick the "Enable/Disable Digital Signature Icon" option.
    2. In the dialog box, uncheck the option.
    3. Restart the computer.
    For AutoCAD LT
    1. Do a search for "AcSignOpt.exe" on your computer.
    2. Uncheck the option in the dialog box.
    AUGI Director scott.wilcox's Avatar
    2015-11
    Edmonton, Alberta
    990
    Default Re: Make Autocad start up a little faster.
    Great tip, Glenn.
    thanks
    100 Club david-k's Avatar
    San Diego, CA
    100
    I didn't even know this option was available.
    This should work for any programs you use on a regular basis.
    100 Club murrayc.49304's Avatar
    2003-03
    158
    Another trick to make AutoCAD run a little faster is to set your Anti Virus software to IGNORE AutoCAD extensions like: DWG, LSP, DCL, ARX, CHM, etc
    9,805
    Here is a direct link to the referenced article [ http://themadcadder.blogs.com/my_web..._the_digi.html ]
    ...and another version (which is almost two years old...) on the HyperPics blog [ http://hyperpics.blogs.com/beyond_th...s_contain.html ]
    AUGI Addict madcadder's Avatar
    Too far from the beach
    1,054
    Quote Originally Posted by Glenndp
    Ahhhh Shh......
    Someone has gone and stole my name....
    I could stop if I wanted to r.grandmaison's Avatar
    2003-11
    location location
    201
    You can also use the "/nologo" switch on your AutoCAD program icon. To find out more, just do a search in the AutoCAD help file and look for "no logo".
    9,805
    Active Member nickeshaffer's Avatar
    2006-01
    Spencer IA
    65
    so what exactly does this do?
    2001-05
    Austin, TX USA
    2,201
    Quote Originally Posted by nickeshaffer
    From Mad Cadders site:
    What does this do? Well, Autodesk applications loads a shell extension which determines if a file is digitally signed by displaying a specific icon. To determine whether a file is digitally signed, the shell extension looks into each drawing file before displaying it. If a folder contains many drawings, like your template folder, it will take longer to open.
  1. Less gadgets, Make AutoCAD simpler and faster
    Last Post: 2011-11-23, 07:17 PM
  2. AutoCAD file became slower to pass any command, how i can make it faster!
    By mohammed.asaduzzaman in forum Productstream - General
    Last Post: 2010-07-15, 06:00 AM
  3. faster start up
    By dmwirtz in forum AutoCAD Customization
    Last Post: 2005-12-07, 10:15 PM
  4. How do I make revit faster?
    By woethesinner in forum Revit Architecture - General
    Last Post: 2004-06-30, 08:42 PM
  5. Making Revit Start faster
    By Scott D Davis in forum Revit Architecture - Tips & Tricks
    Last Post: 2003-06-02, 10:51 AM
